주요 콘텐츠로 건너뛰기
Acer Aspire 774G-58GS Thermal Paste Replacement
필요한 것
  1. Acer Aspire 774G-58GS Thermal Paste Replacement, Thermal Paste: 1 단계, 이미지 1/3 Acer Aspire 774G-58GS Thermal Paste Replacement, Thermal Paste: 1 단계, 이미지 2/3 Acer Aspire 774G-58GS Thermal Paste Replacement, Thermal Paste: 1 단계, 이미지 3/3
    • Remove the three screws from the plate that covers the RAM and HDD using a Phillips #0 screwdriver.
    • Remove the plate from the laptop.
  2. Acer Aspire 774G-58GS Thermal Paste Replacement: 2 단계, 이미지 1/2 Acer Aspire 774G-58GS Thermal Paste Replacement: 2 단계, 이미지 2/2
    • Remove the DVD drive and the three screws that are underneath it.
    • Remove all the screws surrounding the backplate.
  3. Acer Aspire 774G-58GS Thermal Paste Replacement: 3 단계, 이미지 1/3 Acer Aspire 774G-58GS Thermal Paste Replacement: 3 단계, 이미지 2/3 Acer Aspire 774G-58GS Thermal Paste Replacement: 3 단계, 이미지 3/3
    • Disconnect the speaker wire beneath the RAM.
    • Gently remove the backplate from the laptop.
  4. Acer Aspire 774G-58GS Thermal Paste Replacement: 4 단계, 이미지 1/2 Acer Aspire 774G-58GS Thermal Paste Replacement: 4 단계, 이미지 2/2
    • Remove the five screws from the heat sink.
    • Take a cotton ball and dab it with isopropyl alcohol.
    • Use the cotton ball to wipe the old thermal paste from the heat sink.
  5. Acer Aspire 774G-58GS Thermal Paste Replacement: 5 단계, 이미지 1/3 Acer Aspire 774G-58GS Thermal Paste Replacement: 5 단계, 이미지 2/3 Acer Aspire 774G-58GS Thermal Paste Replacement: 5 단계, 이미지 3/3
    • Take another cotton ball, dab it with isopropyl alcohol, and gently wipe the thermal paste off of the GPU and CPU.
    • There is no need to rub hard as it should come off with ease.
    • Once the thermal paste is completely off, let the heat sink dry for a couple of minutes.
    • Apply a dab of new thermal paste in the middle of the CPU and GPU.
    • Corsair TM30 thermal paste is used in this guide.
  6. Acer Aspire 774G-58GS Thermal Paste Replacement: 6 단계, 이미지 1/1
    • Put the heatsink back on and screw it in place.
결론
Abdul Munam Khan
회원 가입일: 01/13/22
133 평판
안내서 1개 작성함
York University, Team 1-12, O'Regan Winter 2022 York University, Team 1-12, O'Regan Winter 2022 회원
YORK-O'REGAN-W22S1G12
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 25
전체 시간: 643
