주요 콘텐츠로 건너뛰기
Acer Aspire 8735G Memory (RAM) Replacement
필요한 것
  1. Acer Aspire 8735G Memory (RAM) Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before proceeding, power down your Laptop and remove the power cable.
    • Close the display and lay it on a flat surface, top-side down.
  2. Acer Aspire 8735G Memory (RAM) Replacement: 2 단계, 이미지 1개 중 1개
    • Unlock the battery by sliding the battery lock to the unlock part.
  3. Acer Aspire 8735G Memory (RAM) Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the middle lock to the right and the battery will pop up.
  4. Acer Aspire 8735G Memory (RAM) Replacement: 4 단계, 이미지 1개 중 1개
    • If you want to replace the battery and nothing else then now is the time to do so.
    • Once the battery hatch is unlocked you can now safely remove the battery.
  5. Acer Aspire 8735G Memory (RAM) Replacement, RAM: 5 단계, 이미지 1개 중 1개
    • Use a Philips J1 driver to remove eight screws securing the bottom case.
    • Remove all of the 8 screws. After that you are in.
  6. Acer Aspire 8735G Memory (RAM) Replacement: 6 단계, 이미지 1개 중 1개
    • Now try to spot the Memory, which is here indistinguishable as a red circle.
  7. Acer Aspire 8735G Memory (RAM) Replacement: 7 단계, 이미지 1개 중 1개
    • Don't remove the ram before pushing the pins.
    • After the previous step, remove the ram by pushing the pins holding it outwards.
  8. Acer Aspire 8735G Memory (RAM) Replacement: 8 단계, 이미지 1개 중 1개
    • If you need to change your memory and nothing else then now is the time to do so. The Acer Aspire 8735G takes DDR3 SO-DIMM ram, upgradeable up-to 8GB.
    • After that the pins jump up and you can carefully remove the ram.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Regome
회원 가입일: 01/20/23
794 평판
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 2
전체 시간: 154
