주요 콘텐츠로 건너뛰기
Acer Aspire A515-51G Lower Case Replacement
필요한 것
  1. Acer Aspire A515-51G Lower Case Replacement, Unfasten the HDD hatch: 1 단계, 이미지 2개 중 1개 Acer Aspire A515-51G Lower Case Replacement, Unfasten the HDD hatch: 1 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the screw securing the HDD hatch on the bottom left of the lower case.
  2. Acer Aspire A515-51G Lower Case Replacement, Remove the HDD hatch: 2 단계, 이미지 3개 중 1개 Acer Aspire A515-51G Lower Case Replacement, Remove the HDD hatch: 2 단계, 이미지 3개 중 2개 Acer Aspire A515-51G Lower Case Replacement, Remove the HDD hatch: 2 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger under the cutout on the top right corner of the HDD hatch and pry it up.
    • Remove the HDD hatch.
  3. Acer Aspire A515-51G Lower Case Replacement, Unfasten the HDD assembly: 3 단계, 이미지 2개 중 1개 Acer Aspire A515-51G Lower Case Replacement, Unfasten the HDD assembly: 3 단계, 이미지 2개 중 2개
    • Your HDD assembly may be secured to the lower case with screws. If it's not, skip this step.
    • Use a Phillips screwdriver to remove the four screws securing the HDD assembly.
  4. Acer Aspire A515-51G Lower Case Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire A515-51G Lower Case Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire A515-51G Lower Case Replacement: 4 단계, 이미지 3개 중 3개
    • Firmly grip the HDD assembly and HDD cable connector head.
    • Pull the HDD cable connector out of its socket.
    • Remove the HDD assembly.
  5. Acer Aspire A515-51G Lower Case Replacement, Unfasten the lower case: 5 단계, 이미지 2개 중 1개 Acer Aspire A515-51G Lower Case Replacement, Unfasten the lower case: 5 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the eighteen 6.6 mm screws securing the case.
  6. Acer Aspire A515-51G Lower Case Replacement, Insert an opening pick: 6 단계, 이미지 2개 중 1개 Acer Aspire A515-51G Lower Case Replacement, Insert an opening pick: 6 단계, 이미지 2개 중 2개
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  7. Acer Aspire A515-51G Lower Case Replacement, Release the case's front clips: 7 단계, 이미지 3개 중 1개 Acer Aspire A515-51G Lower Case Replacement, Release the case's front clips: 7 단계, 이미지 3개 중 2개 Acer Aspire A515-51G Lower Case Replacement, Release the case's front clips: 7 단계, 이미지 3개 중 3개
    • Slide the pick along the front edge to release the clips securing the lower case.
  8. Acer Aspire A515-51G Lower Case Replacement, Release the remaining clips: 8 단계, 이미지 2개 중 1개 Acer Aspire A515-51G Lower Case Replacement, Release the remaining clips: 8 단계, 이미지 2개 중 2개
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  9. Acer Aspire A515-51G Lower Case Replacement: 9 단계, 이미지 3개 중 1개 Acer Aspire A515-51G Lower Case Replacement: 9 단계, 이미지 3개 중 2개 Acer Aspire A515-51G Lower Case Replacement: 9 단계, 이미지 3개 중 3개
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
결론
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Acer Aspire answers community for help.
다른 2명이 해당 안내서를 완성하였습니다.
Spencer Day
회원 가입일: 09/14/22
155,120 평판
안내서 1,033개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 21
지난 30일: 84
전체 시간: 2,610
