주요 콘텐츠로 건너뛰기
Acer Aspire E 11 Battery Replacement
필요한 것
  1. Acer Aspire E 11 Battery Replacement, Lower Case: 1 단계, 이미지 2개 중 1개 Acer Aspire E 11 Battery Replacement, Lower Case: 1 단계, 이미지 2개 중 2개
    • Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
  2. Acer Aspire E 11 Battery Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire E 11 Battery Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire E 11 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Lift the back panel using a plastic opening tool. Slowly make your way around the device until the back panel comes off.
  3. Acer Aspire E 11 Battery Replacement, Battery: 3 단계, 이미지 2개 중 1개 Acer Aspire E 11 Battery Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Press and hold the small black button located on the motherboard just above the battery for five seconds.
  4. Acer Aspire E 11 Battery Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire E 11 Battery Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire E 11 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug.
  5. Acer Aspire E 11 Battery Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire E 11 Battery Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire E 11 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery.
  6. Acer Aspire E 11 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully remove the battery by lifting it out of the casing.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Carlos Rodriguez
회원 가입일: 02/04/16
435 평판
안내서 2개를 작성함
USF Tampa, Team 16-1, Blackwell Winter 2016 USF Tampa, Team 16-1, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G1
4 회원들
안내서 12개를 작성함
댓글 5개
Excellent instructions, very precise and easy to follow. Great job!!!!
[deleted] - 답글
Can I remove the battery and use only the ac adapter to power it? Will it work and not cause damage to the unit?
json_viray - 답글
when you take the battery out it works ok and when you put the battery the orange light when take out the battery its fine could it be the battery or board connector
steve varney - 답글
when battery is out it works fine when connect out and orange and blue light come on then no display remove battery every returns to normal
steve varney - 답글
Thanks - battery replacement carried out successfully by a technical incompetent! This step-by-step guide is much clearer and easier to follow than a video - wish there were more like this out there.
willstac1 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 20
전체 시간: 11,120
