소개
This guide walks you through the proper steps to disconnect and remove the battery from the Laptop.
필요한 것
Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
Press and hold the small black button located on the motherboard just above the battery for five seconds.
Carefully remove the battery by lifting it out of the casing.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 5개
Can I remove the battery and use only the ac adapter to power it? Will it work and not cause damage to the unit?
json_viray - 답글
when you take the battery out it works ok and when you put the battery the orange light when take out the battery its fine could it be the battery or board connector
when battery is out it works fine when connect out and orange and blue light come on then no display remove battery every returns to normal
