주요 콘텐츠로 건너뛰기
Acer Aspire E 11 Motherboard Replacement
필요한 것
  1. Acer Aspire E 11 Motherboard Replacement, Lower Case: 1 단계, 이미지 2개 중 1개 Acer Aspire E 11 Motherboard Replacement, Lower Case: 1 단계, 이미지 2개 중 2개
    • Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
  2. Acer Aspire E 11 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire E 11 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire E 11 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Lift the back panel using a plastic opening tool. Slowly make your way around the device until the back panel comes off.
  3. Acer Aspire E 11 Motherboard Replacement, Battery: 3 단계, 이미지 2개 중 1개 Acer Aspire E 11 Motherboard Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Press and hold the small black button located on the motherboard just above the battery for five seconds.
  4. Acer Aspire E 11 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire E 11 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire E 11 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug.
  5. Acer Aspire E 11 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire E 11 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire E 11 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery.
  6. Acer Aspire E 11 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully remove the battery by lifting it out of the casing.
  7. Acer Aspire E 11 Motherboard Replacement, Motherboard: 7 단계, 이미지 3개 중 1개 Acer Aspire E 11 Motherboard Replacement, Motherboard: 7 단계, 이미지 3개 중 2개 Acer Aspire E 11 Motherboard Replacement, Motherboard: 7 단계, 이미지 3개 중 3개
    • Locate the keyboard cable on the motherboard. Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard.
  8. Acer Aspire E 11 Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Acer Aspire E 11 Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Acer Aspire E 11 Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to carefully lift the white hinge up on the touchpad cable connector, and gently remove the cable from the motherboard.
  9. Acer Aspire E 11 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Acer Aspire E 11 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Acer Aspire E 11 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Use two plastic opening tools to grip each side of the connector for the speaker cable and gently pull the cable from the motherboard.
  10. Acer Aspire E 11 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Acer Aspire E 11 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Acer Aspire E 11 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the tape on the connector for the display cable.
    • Use two plastic opening tools to grip each side of the connector and gently pull the display cable from the motherboard.
  11. Acer Aspire E 11 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Acer Aspire E 11 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Remove one 6.2 mm Phillips #1 screw from the wireless chip on the left side of the motherboard.
  12. Acer Aspire E 11 Motherboard Replacement: 12 단계, 이미지 3개 중 1개 Acer Aspire E 11 Motherboard Replacement: 12 단계, 이미지 3개 중 2개 Acer Aspire E 11 Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Remove three 6.2 mm Phillips #1 screws that attach the motherboard to the laptop casing.
  13. Acer Aspire E 11 Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Return to the wireless chip and gently pull it from the connector on the side of the motherboard.
  14. Acer Aspire E 11 Motherboard Replacement: 14 단계, 이미지 1개 중 1개
    • The motherboard can now be lifted out from the laptop casing.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Carlos Rodriguez
회원 가입일: 02/04/16
435 평판
안내서 2개를 작성함
USF Tampa, Team 16-1, Blackwell Winter 2016 USF Tampa, Team 16-1, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G1
4 회원들
안내서 12개를 작성함
댓글 3개
Some of the bullet points can be broken up into information points or divided into more bullet points per step. Also, make sure the exposure is high enough to make all parts visible
Jaie Hillery - 답글
Hello, What is WiFi+BT card model ? Is it Atheros?
Da K - 답글
Me podrían decir cual es el modelo de la pila del BIOS de este modelo e11 , por favor
Jesus Quiroz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 26
전체 시간: 5,573
