주요 콘텐츠로 건너뛰기
Acer Aspire E1-470P-6659 Cooling Fan Replacement
필요한 것
  1. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the laptop and disconnect all device cords.
  2. Acer Aspire E1-470P-6659 Cooling Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the laptop over so the bottom is facing you.
  3. Acer Aspire E1-470P-6659 Cooling Fan Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire E1-470P-6659 Cooling Fan Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire E1-470P-6659 Cooling Fan Replacement: 3 단계, 이미지 3개 중 3개
    • Use your finger or a spuger to pull the battery release switch.
  4. Acer Aspire E1-470P-6659 Cooling Fan Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire E1-470P-6659 Cooling Fan Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire E1-470P-6659 Cooling Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the battery from the laptop.
  5. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Hard Drive: 5 단계, 이미지 2개 중 1개 Acer Aspire E1-470P-6659 Cooling Fan Replacement, Hard Drive: 5 단계, 이미지 2개 중 2개
    • Remove nineteen screws from the back panel using a Phillips #0 Screwdriver .
  6. Acer Aspire E1-470P-6659 Cooling Fan Replacement: 6 단계, 이미지 3개 중 1개 Acer Aspire E1-470P-6659 Cooling Fan Replacement: 6 단계, 이미지 3개 중 2개 Acer Aspire E1-470P-6659 Cooling Fan Replacement: 6 단계, 이미지 3개 중 3개
    • Run the plastic opening tool across from one corner to another along the edge.
    • Separate the keyboard panel gently.
    • Lift the keyboard slowly from the laptop but do not lift completely because there are ribbon cables attached.
  7. Acer Aspire E1-470P-6659 Cooling Fan Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire E1-470P-6659 Cooling Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the two keyboard assembly ribbon cables from motherboard.
    • To release small ribbon cable, use spudger or fingers to flip gray bar along edge over.
    • To release larger ribbon cable, use pry tool or spudger to slide white plastic clip forward.
  8. Acer Aspire E1-470P-6659 Cooling Fan Replacement: 8 단계, 이미지 1개 중 1개
    • Pull up the release tab beside the hard drive.
    • Disconnect portion of ribbon cable that is covering the hard drive.
    • Handle the ribbon carefully. Do not break the metal contact.
    • While reconnecting the ribbon after replacing a new hard drive, face the blue side with a label up. Make sure the black line beside the sticker is not crooked, so that the ribbon is tight.
  9. Acer Aspire E1-470P-6659 Cooling Fan Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the hard drive screw using Phillips #0 Screwdriver.
  10. Acer Aspire E1-470P-6659 Cooling Fan Replacement: 10 단계, 이미지 1개 중 1개
    • Pull the hard drive out gently. Be aware that it is connected to the adapter.
    • Gently remove adapter by pulling on both ends simultaneously to separate it from the hard drive.
  11. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Motherboard: 11 단계, 이미지 3개 중 1개 Acer Aspire E1-470P-6659 Cooling Fan Replacement, Motherboard: 11 단계, 이미지 3개 중 2개 Acer Aspire E1-470P-6659 Cooling Fan Replacement, Motherboard: 11 단계, 이미지 3개 중 3개
    • Remove additional screws that can be found on the motherboard.
    • Remove the green wifi card from motherboard.
    • Use spudger to disconnect the fan and motherboard from laptop.
  12. Acer Aspire E1-470P-6659 Cooling Fan Replacement: 12 단계, 이미지 2개 중 1개 Acer Aspire E1-470P-6659 Cooling Fan Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the cable attached to motherboard.
    • Gently lift and remove the motherboard from the laptop.
  13. Acer Aspire E1-470P-6659 Cooling Fan Replacement, Cooling Fan: 13 단계, 이미지 2개 중 1개 Acer Aspire E1-470P-6659 Cooling Fan Replacement, Cooling Fan: 13 단계, 이미지 2개 중 2개
    • Flip the motherboard and fan piece over.
    • Remove the four screws using the Phillips #000 Screwdriver.
  14. Acer Aspire E1-470P-6659 Cooling Fan Replacement: 14 단계, 이미지 3개 중 1개 Acer Aspire E1-470P-6659 Cooling Fan Replacement: 14 단계, 이미지 3개 중 2개 Acer Aspire E1-470P-6659 Cooling Fan Replacement: 14 단계, 이미지 3개 중 3개
    • Flip the motherboard over and slowly remove the tape holding the cooling fan down.
    • Use a spudger to remove the top of the fan from the base of the fan.
    • Remove the cooling fan component from both the tape and the motherboard.
결론
작성자
2다른 기여자 명과 함께
Faith Lobaton
회원 가입일: 10/22/18
518 평판
안내서 3개를 작성함
UC Davis, Team S4-G5, Lore Fall 2018 UC Davis, Team S4-G5, Lore Fall 2018 회원
UCD-LORE-F18S4G5
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 22
전체 시간: 593
