주요 콘텐츠로 건너뛰기
Acer Aspire E1-510-2500 Battery Replacement
필요한 것
  1. Acer Aspire E1-510-2500 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure that your laptop is completely switched off, and disconnected from the power source.
    • Flip the laptop so that the base of the laptop is facing up.
  2. Acer Aspire E1-510-2500 Battery Replacement: 2 단계, 이미지 1/2 Acer Aspire E1-510-2500 Battery Replacement: 2 단계, 이미지 2/2
    • Insert a spudger into the battery release latch.
    • Slide the battery release latch to the right, this will eject the battery for safe removal.
  3. Acer Aspire E1-510-2500 Battery Replacement: 3 단계, 이미지 1/2 Acer Aspire E1-510-2500 Battery Replacement: 3 단계, 이미지 2/2
    • Carefully slide the battery out of the battery's home.
결론
Sebastian Taylor
회원 가입일: 10/19/17
733 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S2-G5, Julie Fall 2017 UMass Dartmouth, Team S2-G5, Julie Fall 2017 회원
UMASSD-JULIE-F17S2G5
3 회원들
안내서 6개 작성하였습니다
댓글 2개
Hello ifixit i disassembled my Acer aspire e1 laptop.....Then after i finshed assembling it.....The led light would show is charging but computer refuse to turn on...
Steve Gregg - 답글
very nicelyexplained
Jeffrey Joseph - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 33
전체 시간: 3,275
