이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Insert a spudger into the battery release latch.
Slide the battery release latch to the right, this will eject the battery for safe removal.
Using a Phillips 1 screwdriver, remove the 17 9 mm screws from the bottom of the laptop, including the one in the back panel.
Using a plastic opening tool, carefully remove the back panel.
Remove the 9mm screw under the back panel.
Using a plastic opening tool, carefully separate the frame along the edges of the laptop. This should separate the keyboard assembly from the bottom portion of the laptop.
Open the laptop, leaving the screen flat on the table.
Carefully pull the keyboard assembly out away from the base of the laptop. There should be three connections visible in the gap between the keyboard assembly and the base.
Using tweezers, carefully detach the connections from the base.
Place the keyboard assembly and the disk tray place holder aside.
Remove the six wire connections to the motherboard.
Remove the tape connection by lifting the plastic black holding piece and carefully pulling the tape out of it's slot.
Using a Phillips 1 screwdriver, remove the two 5mm screws from the motherboard.
Using a Phillips 1 screwdriver, remove the black 5mm screw from the fan.
Using a Phillips 1 screwdriver, remove the black 3mm screw from the WiFi card.
Carefully remove the motherboard by lifting along the right edge first.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
The wude blue touchpad ribbon is difficult to use, what is the correct way to remove/replace it?
