주요 콘텐츠로 건너뛰기
Acer Aspire E1-510-2500 RAM Card Replacement
필요한 것
  1. Acer Aspire E1-510-2500 RAM Card Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure that your laptop is completely switched off, and disconnected from the power source.
    • Flip the laptop so that the base of the laptop is facing up.
  2. Acer Aspire E1-510-2500 RAM Card Replacement: 2 단계, 이미지 1/2 Acer Aspire E1-510-2500 RAM Card Replacement: 2 단계, 이미지 2/2
    • Insert a spudger into the battery release latch.
    • Slide the battery release latch to the right, this will eject the battery for safe removal.
  3. Acer Aspire E1-510-2500 RAM Card Replacement: 3 단계, 이미지 1/2 Acer Aspire E1-510-2500 RAM Card Replacement: 3 단계, 이미지 2/2
    • Carefully slide the battery out of the battery's home.
  4. Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: 4 단계, 이미지 1/2 Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: 4 단계, 이미지 2/2
    • Using a Phillips 1 screwdriver, remove the 9 mm screw which secures the back panel.
  5. Acer Aspire E1-510-2500 RAM Card Replacement: 5 단계, 이미지 1/2 Acer Aspire E1-510-2500 RAM Card Replacement: 5 단계, 이미지 2/2
    • Use a plastic opening tool to carefully pry the back panel from its home.
    • When reassembling, insert the panel from the edge opposite the screw first.
  6. Acer Aspire E1-510-2500 RAM Card Replacement: 6 단계, 이미지 1/3 Acer Aspire E1-510-2500 RAM Card Replacement: 6 단계, 이미지 2/3 Acer Aspire E1-510-2500 RAM Card Replacement: 6 단계, 이미지 3/3
    • Locate the tabs on either side of the RAM card.
    • Push out on both tabs simultaneously to release the RAM card.
    • The RAM card should raise slightly at the unattached edge.
  7. Acer Aspire E1-510-2500 RAM Card Replacement: 7 단계, 이미지 1/2 Acer Aspire E1-510-2500 RAM Card Replacement: 7 단계, 이미지 2/2
    • Carefully remove the RAM card from its home.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sebastian Taylor
회원 가입일: 10/19/17
733 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S2-G5, Julie Fall 2017 UMass Dartmouth, Team S2-G5, Julie Fall 2017 회원
UMASSD-JULIE-F17S2G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 11
전체 시간: 558
