주요 콘텐츠로 건너뛰기
Acer Aspire E1-510-2500 RAM Card Replacement
필요한 것
  1. Acer Aspire E1-510-2500 RAM Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Ensure that your laptop is completely switched off, and disconnected from the power source.
    • Flip the laptop so that the base of the laptop is facing up.
  2. Acer Aspire E1-510-2500 RAM Card Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire E1-510-2500 RAM Card Replacement: 2 단계, 이미지 2개 중 2개
    • Insert a spudger into the battery release latch.
    • Slide the battery release latch to the right, this will eject the battery for safe removal.
  3. Acer Aspire E1-510-2500 RAM Card Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire E1-510-2500 RAM Card Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully slide the battery out of the battery's home.
  4. Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: 4 단계, 이미지 2개 중 1개 Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: 4 단계, 이미지 2개 중 2개
    • Using a Phillips 1 screwdriver, remove the 9 mm screw which secures the back panel.
  5. Acer Aspire E1-510-2500 RAM Card Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire E1-510-2500 RAM Card Replacement: 5 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to carefully pry the back panel from its home.
    • When reassembling, insert the panel from the edge opposite the screw first.
  6. Acer Aspire E1-510-2500 RAM Card Replacement: 6 단계, 이미지 3개 중 1개 Acer Aspire E1-510-2500 RAM Card Replacement: 6 단계, 이미지 3개 중 2개 Acer Aspire E1-510-2500 RAM Card Replacement: 6 단계, 이미지 3개 중 3개
    • Locate the tabs on either side of the RAM card.
    • Push out on both tabs simultaneously to release the RAM card.
    • The RAM card should raise slightly at the unattached edge.
  7. Acer Aspire E1-510-2500 RAM Card Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire E1-510-2500 RAM Card Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully remove the RAM card from its home.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sebastian Taylor
회원 가입일: 10/19/17
757 평판
안내서 6개를 작성함
UMass Dartmouth, Team S2-G5, Julie Fall 2017 UMass Dartmouth, Team S2-G5, Julie Fall 2017 회원
UMASSD-JULIE-F17S2G5
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 23
지난 7일: 230
지난 30일: 324
전체 시간: 1,063
