주요 콘텐츠로 건너뛰기
Acer Aspire E1-510P-4637 Hard Drive Replacement
필요한 것
  1. Acer Aspire E1-510P-4637 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Remove the M2.5x8 screw with a PH1 screwdriver.
  4. Acer Aspire E1-510P-4637 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Use the plastic opening tool to pop off the small back cover.
  5. Acer Aspire E1-510P-4637 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Use a PH0 Phillips screwdriver to remove the screw securing the hard drive.
  6. Acer Aspire E1-510P-4637 Hard Drive Replacement: 6 단계, 이미지 1/2 Acer Aspire E1-510P-4637 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Use a nylon spudger to slightly pry up the hard drive near the screw holes.
  7. Acer Aspire E1-510P-4637 Hard Drive Replacement: 7 단계, 이미지 1/3 Acer Aspire E1-510P-4637 Hard Drive Replacement: 7 단계, 이미지 2/3 Acer Aspire E1-510P-4637 Hard Drive Replacement: 7 단계, 이미지 3/3
    • Grab hold of the plastic tab and pull the hard drive away from the connectors. This will release the hard drive.
    • The hard drive connector is fragile. Handle with care.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Caleb lindsay
회원 가입일: 04/11/16
778 평판
안내서 6개 작성하였습니다
Cal Poly, Team 34-15, Maness Spring 2016 Cal Poly, Team 34-15, Maness Spring 2016 회원
CPSU-MANESS-S16S34G15
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 1,925
