주요 콘텐츠로 건너뛰기
Acer Aspire E1-510P-4637 Keyboard Replacement
필요한 것
  1. Acer Aspire E1-510P-4637 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 Keyboard Replacement, Hard Drive: 3 단계, 이미지 1개 중 1개
    • Remove the M2.5x8 screw with a PH1 screwdriver.
  4. Acer Aspire E1-510P-4637 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to pop off the small back cover.
  5. Acer Aspire E1-510P-4637 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Use a PH0 Phillips screwdriver to remove the screw securing the hard drive.
  6. Acer Aspire E1-510P-4637 Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire E1-510P-4637 Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Use a nylon spudger to slightly pry up the hard drive near the screw holes.
  7. Acer Aspire E1-510P-4637 Keyboard Replacement: 7 단계, 이미지 3개 중 1개 Acer Aspire E1-510P-4637 Keyboard Replacement: 7 단계, 이미지 3개 중 2개 Acer Aspire E1-510P-4637 Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Grab hold of the plastic tab and pull the hard drive away from the connectors. This will release the hard drive.
    • The hard drive connector is fragile. Handle with care.
  8. Acer Aspire E1-510P-4637 Keyboard Replacement, Keyboard: 8 단계, 이미지 1개 중 1개
    • Remove the fourteen M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Slide out the disk drive tray.
  10. Acer Aspire E1-510P-4637 Keyboard Replacement: 10 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to gently pry open the laptop.
  11. Acer Aspire E1-510P-4637 Keyboard Replacement: 11 단계, 이미지 3개 중 1개 Acer Aspire E1-510P-4637 Keyboard Replacement: 11 단계, 이미지 3개 중 2개 Acer Aspire E1-510P-4637 Keyboard Replacement: 11 단계, 이미지 3개 중 3개
    • Rotate the back cover up a little to reveal the cables connected to the motherboard.
    • Unplug the cables by sliding them out of their receptacle.
    • The connectors are very small and fragile. Handle with care.
  12. Acer Aspire E1-510P-4637 Keyboard Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the four center panel M1.6x3 screws with a PH0 Phillips screwdriver.
    • Remove the two M2x3 screws with a PH0 Phillips screwdriver.
  13. Acer Aspire E1-510P-4637 Keyboard Replacement: 13 단계, 이미지 3개 중 1개 Acer Aspire E1-510P-4637 Keyboard Replacement: 13 단계, 이미지 3개 중 2개 Acer Aspire E1-510P-4637 Keyboard Replacement: 13 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to slide the metal part out to release it from the retaining tabs.
  14. Acer Aspire E1-510P-4637 Keyboard Replacement: 14 단계, 이미지 2개 중 1개 Acer Aspire E1-510P-4637 Keyboard Replacement: 14 단계, 이미지 2개 중 2개
    • Peel off the foil adhesive stuck to the keyboard.
  15. Acer Aspire E1-510P-4637 Keyboard Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the keyboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Caleb lindsay
회원 가입일: 04/11/16
814 평판
안내서 6개를 작성함
Cal Poly, Team 34-15, Maness Spring 2016 Cal Poly, Team 34-15, Maness Spring 2016 회원
CPSU-MANESS-S16S34G15
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 12
전체 시간: 1,322
