주요 콘텐츠로 건너뛰기
Acer Aspire E1-510P-4637 Touch Screen Display Replacement
필요한 것
  1. Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Battery: 1 단계, 이미지 1/1
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 2 단계, 이미지 1/1
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Touch Screen Display: 3 단계, 이미지 1/3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Touch Screen Display: 3 단계, 이미지 2/3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Touch Screen Display: 3 단계, 이미지 3/3
    • Remove the plastic screw covers located near the laptop's hinge using a metal spudger.
    • Remove the two M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  4. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 4 단계, 이미지 1/3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 4 단계, 이미지 2/3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 4 단계, 이미지 3/3
    • Flip the laptop over and open it up so the screen is facing up and the top of the screen is facing you.
    • Use a plastic opening tool to separate the the touchscreen from the back cover.
    • Carefully work your way around the frame and gently pry. Be careful not to brake the frame or damage the screen.
  5. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 5 단계, 이미지 1/3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 5 단계, 이미지 2/3 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 5 단계, 이미지 3/3
    • Disconnect the display cable by first taking off the tape using a metal spudger and then pulling on the black tab.
  6. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 6 단계, 이미지 1/2 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 6 단계, 이미지 2/2
    • Take off the yellow tape connecting the display to the border.
  7. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 7 단계, 이미지 1/2 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 7 단계, 이미지 2/2
    • Pull back the adhesive using the metal spudger.
    • Pry out the camera by lifting the adhesive with the metal spudger. Then, remove the camera by lifting it up by one side.
  8. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 8 단계, 이미지 1/1
    • Remove the two brackets holding the displays by unscrewing both M1 .6x3 screws with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: 9 단계, 이미지 1/1
    • Release the display from the border using your hands.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Caleb lindsay
회원 가입일: 04/11/16
778 평판
안내서 6개 작성하였습니다
Cal Poly, Team 34-15, Maness Spring 2016 Cal Poly, Team 34-15, Maness Spring 2016 회원
CPSU-MANESS-S16S34G15
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
the touchscreen its glue together with the LCD?
Chris Foliaki - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 1,197
