주요 콘텐츠로 건너뛰기
Acer Aspire E1-531-2438 Screen Replacement
필요한 것
  1. Acer Aspire E1-531-2438 Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Aspire E1-531-2438 Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 Screen Replacement, Hard Drive: 3 단계, 이미지 2개 중 1개 Acer Aspire E1-531-2438 Screen Replacement, Hard Drive: 3 단계, 이미지 2개 중 2개
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
  4. Acer Aspire E1-531-2438 Screen Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire E1-531-2438 Screen Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire E1-531-2438 Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Using the indentation, pry open the access panel with your fingers or a spudger.
    • Remove the access panel to expose the hard drive, WiFi chip, and RAM modules.
  5. Acer Aspire E1-531-2438 Screen Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire E1-531-2438 Screen Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire E1-531-2438 Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Grip the plastic tab on the hard drive, then pull to the left to unplug the drive from its socket.
    • Once free from the socket, lift the hard drive up and out of the device.
  6. Acer Aspire E1-531-2438 Screen Replacement, Screen: 6 단계, 이미지 3개 중 1개 Acer Aspire E1-531-2438 Screen Replacement, Screen: 6 단계, 이미지 3개 중 2개 Acer Aspire E1-531-2438 Screen Replacement, Screen: 6 단계, 이미지 3개 중 3개
    • Using a Phillips #0 screwdriver, remove all of the following screws:
    • Fifteen 9mm screws
    • One 6mm screw
    • Three 3.5mm screws
  7. Acer Aspire E1-531-2438 Screen Replacement: 7 단계, 이미지 3개 중 1개 Acer Aspire E1-531-2438 Screen Replacement: 7 단계, 이미지 3개 중 2개 Acer Aspire E1-531-2438 Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the optical drive by sliding it out of its slot on the side of the laptop.
  8. Acer Aspire E1-531-2438 Screen Replacement: 8 단계, 이미지 2개 중 1개 Acer Aspire E1-531-2438 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, pry along the seam running the perimeter of the laptop to separate the bottom case from the palmrest assembly.
    • Flip the device over and open the laptop so that the keyboard is visible.
    • Lift up the palmrest assembly just far enough to access the connectors underneath.
  9. Acer Aspire E1-531-2438 Screen Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire E1-531-2438 Screen Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using a pair of tweezers, disconnect the small white ribbon cable from the connector near the left side of the device.
    • Disconnect the large black ribbon cable near the middle of the device. Gently pull on the cable away from you.
  10. Acer Aspire E1-531-2438 Screen Replacement: 10 단계, 이미지 2개 중 1개 Acer Aspire E1-531-2438 Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Lift and remove the palmrest assembly and the attached keyboard.
  11. Acer Aspire E1-531-2438 Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Using two hands, push toward the screen to disconnect the screen connector.
  12. Acer Aspire E1-531-2438 Screen Replacement: 12 단계, 이미지 2개 중 1개 Acer Aspire E1-531-2438 Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Using a spudger, remove the circular plastic screw cover on the screws on the lower left and right of the screen.
    • Using a Phillips #0 screwdriver, remove the two 3mm screws hidden under the circular plastic screw covers.
  13. Acer Aspire E1-531-2438 Screen Replacement: 13 단계, 이미지 3개 중 1개 Acer Aspire E1-531-2438 Screen Replacement: 13 단계, 이미지 3개 중 2개 Acer Aspire E1-531-2438 Screen Replacement: 13 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, go around the edge of the display to remove the plastic bezel.
  14. Acer Aspire E1-531-2438 Screen Replacement: 14 단계, 이미지 2개 중 1개 Acer Aspire E1-531-2438 Screen Replacement: 14 단계, 이미지 2개 중 2개
    • Using a Phillips #0 screwdriver, remove the three screws in the mounting bracket along the right edge of the screen.
    • Remove the three screws in the mounting bracket along the left edge of the screen in the same manner.
    • Lift the screen out of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jakob Rinkus
회원 가입일: 03/21/19
965 평판
안내서 7개를 작성함
UMass Dartmouth, Team S8-G2, Bailey Spring 2019 UMass Dartmouth, Team S8-G2, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S8G2
3 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 28
지난 30일: 34
전체 시간: 992
