주요 콘텐츠로 건너뛰기
Acer Aspire E1-531-2438 Wifi Card Replacement
필요한 것
  1. Acer Aspire E1-531-2438 Wifi Card Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Aspire E1-531-2438 Wifi Card Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 Wifi Card Replacement: 2 단계, 이미지 1개 중 1개
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 Wifi Card Replacement, WiFi Card: 3 단계, 이미지 2개 중 1개 Acer Aspire E1-531-2438 Wifi Card Replacement, WiFi Card: 3 단계, 이미지 2개 중 2개
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
  4. Acer Aspire E1-531-2438 Wifi Card Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire E1-531-2438 Wifi Card Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire E1-531-2438 Wifi Card Replacement: 4 단계, 이미지 3개 중 3개
    • Using the indentation, pry open the access panel with your fingers or a spudger.
    • Remove the access panel to expose the hard drive, WiFi card, and RAM modules.
  5. Acer Aspire E1-531-2438 Wifi Card Replacement: 5 단계, 이미지 1개 중 1개
    • Using a spudger, disconnect the two antenna cables connectors on the WiFi card.
  6. Acer Aspire E1-531-2438 Wifi Card Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire E1-531-2438 Wifi Card Replacement: 6 단계, 이미지 2개 중 2개
    • Using a Phillips #0 screwdriver, remove the 3mm screw holding the WiFi card in place.
    • The card will then lift up after the screw is removed.
    • Remove the card by pulling out in the direction that the card is now orientated.
결론
작성자
2다른 기여자 명과 함께
Jakob Rinkus
회원 가입일: 03/21/19
965 평판
안내서 7개를 작성함
UMass Dartmouth, Team S8-G2, Bailey Spring 2019 UMass Dartmouth, Team S8-G2, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S8G2
3 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 26
전체 시간: 1,064
