주요 콘텐츠로 건너뛰기
Acer Aspire E1-572-6829 Battery Replacement
필요한 것
  1. Acer Aspire E1-572-6829 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Before beginning, make sure the laptop is turned off and the charger is unplugged.
    • Flip the laptop over so that you are facing the back panel.
    • Locate the battery lock switch below the battery.
  2. Acer Aspire E1-572-6829 Battery Replacement: 2 단계, 이미지 1/3 Acer Aspire E1-572-6829 Battery Replacement: 2 단계, 이미지 2/3 Acer Aspire E1-572-6829 Battery Replacement: 2 단계, 이미지 3/3
    • Slide the battery lock switch to the open position using your finger or a plastic spudger.
    • While holding this switch open, use your other hand to slide the battery out from the back of the laptop.
    • Your battery is removed. You can now let go of the lock switch.
    • To reinsert the battery, make sure that it's tabs are lined up with the laptop and that it is facing in the right direction. Then slide it straight back in without using the lock switch.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lauren Donlan
회원 가입일: 03/13/23
112 평판
안내서 1개 작성함
UMass Dartmouth, Team 2-2, Petersen Spring 2023 UMass Dartmouth, Team 2-2, Petersen Spring 2023 회원
UMASSD-PETERSEN-S23S2G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 11
전체 시간: 198
