주요 콘텐츠로 건너뛰기
Acer Aspire E1-572-6829 Hard Disk Replacement
필요한 것
  1. Acer Aspire E1-572-6829 Hard Disk Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before beginning, make sure the laptop is turned off and the charger is unplugged.
    • Flip the laptop over so that you are facing the back panel.
    • Locate the battery lock switch below the battery.
  2. Acer Aspire E1-572-6829 Hard Disk Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire E1-572-6829 Hard Disk Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire E1-572-6829 Hard Disk Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the battery lock switch to the open position using your finger or a plastic spudger.
    • While holding this switch open, use your other hand to slide the battery out from the back of the laptop.
    • Your battery is removed. You can now let go of the lock switch.
    • To reinsert the battery, make sure that it's tabs are lined up with the laptop and that it is facing in the right direction. Then slide it straight back in without using the lock switch.
  3. Acer Aspire E1-572-6829 Hard Disk Replacement, Hard Disk: 3 단계, 이미지 3개 중 1개 Acer Aspire E1-572-6829 Hard Disk Replacement, Hard Disk: 3 단계, 이미지 3개 중 2개 Acer Aspire E1-572-6829 Hard Disk Replacement, Hard Disk: 3 단계, 이미지 3개 중 3개
    • Remove the 8 mm screw holding down the lower back panel using a Phillips #0 screwdriver.
    • Use a plastic spudger or a similar tool to pry open the panel from the top edge.
    • Lift up the panel to remove it.
  4. Acer Aspire E1-572-6829 Hard Disk Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire E1-572-6829 Hard Disk Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire E1-572-6829 Hard Disk Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the two 8 mm Phillips #0 screws holding the Hard Disk tray.
    • Once both screws are removed, use the tab on the left to slide the hard disk tray out from the SATA port.
    • Once the tray is pulled out to the left, the assembly can safely be removed from the laptop.
  5. Acer Aspire E1-572-6829 Hard Disk Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire E1-572-6829 Hard Disk Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire E1-572-6829 Hard Disk Replacement: 5 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to remove the two 2 mm screws (one on each side) attaching the hard disk to the hard disk tray.
  6. Acer Aspire E1-572-6829 Hard Disk Replacement: 6 단계, 이미지 3개 중 1개 Acer Aspire E1-572-6829 Hard Disk Replacement: 6 단계, 이미지 3개 중 2개 Acer Aspire E1-572-6829 Hard Disk Replacement: 6 단계, 이미지 3개 중 3개
    • Once the screws have been removed, the hard disk can be separated from the tray.
결론
작성자
3다른 기여자 명과 함께
Anamika Menon
회원 가입일: 03/13/23
514 평판
안내서 5개를 작성함
UMass Dartmouth, Team 2-2, Petersen Spring 2023 UMass Dartmouth, Team 2-2, Petersen Spring 2023 회원
UMASSD-PETERSEN-S23S2G2
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 376
