주요 콘텐츠로 건너뛰기
Acer Aspire E3-111-C0WA RAM Replacement
필요한 것
  1. Acer Aspire E3-111-C0WA RAM Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA RAM Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
  2. Acer Aspire E3-111-C0WA RAM Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire E3-111-C0WA RAM Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire E3-111-C0WA RAM Replacement: 2 단계, 이미지 3개 중 3개
    • Insert your plastic opening tool between the bottom case and the rest of the laptop.
    • Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
    • Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
    • Lift the bottom off the laptop.
  3. Acer Aspire E3-111-C0WA RAM Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA RAM Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Make sure you have properly grounded yourself to avoid potentially damaging any internal components by wearing the anti-static wrist strap and attaching the clip end to metal.
    • Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
  4. Acer Aspire E3-111-C0WA RAM Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire E3-111-C0WA RAM Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire E3-111-C0WA RAM Replacement: 4 단계, 이미지 3개 중 3개
    • Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
  5. Acer Aspire E3-111-C0WA RAM Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA RAM Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
  6. Acer Aspire E3-111-C0WA RAM Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA RAM Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the battery up and off the rest of the laptop.
  7. Acer Aspire E3-111-C0WA RAM Replacement, Wireless Card: 7 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA RAM Replacement, Wireless Card: 7 단계, 이미지 2개 중 2개
    • Remove the two antenna cables from the wireless card. These should snap lightly out of place when lifted upwards.
  8. Acer Aspire E3-111-C0WA RAM Replacement: 8 단계, 이미지 3개 중 1개 Acer Aspire E3-111-C0WA RAM Replacement: 8 단계, 이미지 3개 중 2개 Acer Aspire E3-111-C0WA RAM Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the 6.2mm #1 Phillips head screw attaching the wireless card to the case.
    • Pull the wireless card horizontally away from the motherboard to remove it from the connector.
  9. Acer Aspire E3-111-C0WA RAM Replacement, Hard Drive: 9 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA RAM Replacement, Hard Drive: 9 단계, 이미지 2개 중 2개
    • Holding the laptop in place, slide the hard drive horizontally out from the SATA connector.
  10. Acer Aspire E3-111-C0WA RAM Replacement, RAM: 10 단계, 이미지 3개 중 1개 Acer Aspire E3-111-C0WA RAM Replacement, RAM: 10 단계, 이미지 3개 중 2개 Acer Aspire E3-111-C0WA RAM Replacement, RAM: 10 단계, 이미지 3개 중 3개
    • Lightly pry upwards on the black plastic tab to release the touchpad cable, then gently pull the cable from the connector.
  11. Acer Aspire E3-111-C0WA RAM Replacement: 11 단계, 이미지 3개 중 1개 Acer Aspire E3-111-C0WA RAM Replacement: 11 단계, 이미지 3개 중 2개 Acer Aspire E3-111-C0WA RAM Replacement: 11 단계, 이미지 3개 중 3개
    • Find the keyboard cable. Pull the two gray plastic tabs outwards to release the ribbon. Gently pull the cable from the connector.
  12. Acer Aspire E3-111-C0WA RAM Replacement: 12 단계, 이미지 3개 중 1개 Acer Aspire E3-111-C0WA RAM Replacement: 12 단계, 이미지 3개 중 2개 Acer Aspire E3-111-C0WA RAM Replacement: 12 단계, 이미지 3개 중 3개
    • Pull down gently on the black speaker cable connector to disconnect it from the motherboard.
  13. Acer Aspire E3-111-C0WA RAM Replacement: 13 단계, 이미지 3개 중 1개 Acer Aspire E3-111-C0WA RAM Replacement: 13 단계, 이미지 3개 중 2개 Acer Aspire E3-111-C0WA RAM Replacement: 13 단계, 이미지 3개 중 3개
    • Peel up the tape adhering the display cable to the connector on the motherboard.
    • Slide the display cable horizontally out of the connector to remove it from the motherboard.
  14. Acer Aspire E3-111-C0WA RAM Replacement: 14 단계, 이미지 3개 중 1개 Acer Aspire E3-111-C0WA RAM Replacement: 14 단계, 이미지 3개 중 2개 Acer Aspire E3-111-C0WA RAM Replacement: 14 단계, 이미지 3개 중 3개
    • Unscrew the four 6.2mm Phillips #1 screws attaching the motherboard to the case.
    • With all the screws and cables detached, lift the motherboard directly upwards out of the case.
  15. Acer Aspire E3-111-C0WA RAM Replacement: 15 단계, 이미지 3개 중 1개 Acer Aspire E3-111-C0WA RAM Replacement: 15 단계, 이미지 3개 중 2개 Acer Aspire E3-111-C0WA RAM Replacement: 15 단계, 이미지 3개 중 3개
    • Flip over the motherboard after removing it from the case.
    • Apply pressure outward on the metal tabs on either side of the RAM stick to release them from the notches on the stick.
    • The RAM stick may be under some tension and potentially fly out of the socket if not held in place as the tabs are released.
    • After the tabs have been released, slide the RAM out of the slot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jonathan Chandler
회원 가입일: 10/17/17
503 평판
안내서 4개를 작성함
UC Santa Barbara, Team S1-G2, Weedon Fall 2017 UC Santa Barbara, Team S1-G2, Weedon Fall 2017 회원
UCSB-WEEDON-F17S1G2
5 회원들
안내서 5개를 작성함
댓글 한 개
Thank you for this very well done step by step guide! I updated the RAM in this computer with no issues because of your procedure. FYI - I am a fellow Gaucho graduate way back from the Class of 1981.
Brian Satow - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 1,078
