주요 콘텐츠로 건너뛰기
Acer Aspire E3-111-C0WA Wireless Card Replacement
필요한 것
  1. Acer Aspire E3-111-C0WA Wireless Card Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA Wireless Card Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
  2. Acer Aspire E3-111-C0WA Wireless Card Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire E3-111-C0WA Wireless Card Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire E3-111-C0WA Wireless Card Replacement: 2 단계, 이미지 3개 중 3개
    • Insert your plastic opening tool between the bottom case and the rest of the laptop.
    • Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
    • Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
    • Lift the bottom off the laptop.
  3. Acer Aspire E3-111-C0WA Wireless Card Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA Wireless Card Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Make sure you have properly grounded yourself to avoid potentially damaging any internal components by wearing the anti-static wrist strap and attaching the clip end to metal.
    • Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
  4. Acer Aspire E3-111-C0WA Wireless Card Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire E3-111-C0WA Wireless Card Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire E3-111-C0WA Wireless Card Replacement: 4 단계, 이미지 3개 중 3개
    • Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
  5. Acer Aspire E3-111-C0WA Wireless Card Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA Wireless Card Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
  6. Acer Aspire E3-111-C0WA Wireless Card Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA Wireless Card Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the battery up and off the rest of the laptop.
  7. Acer Aspire E3-111-C0WA Wireless Card Replacement, Wireless Card: 7 단계, 이미지 2개 중 1개 Acer Aspire E3-111-C0WA Wireless Card Replacement, Wireless Card: 7 단계, 이미지 2개 중 2개
    • Remove the two antenna cables from the wireless card. These should snap lightly out of place when lifted upwards.
  8. Acer Aspire E3-111-C0WA Wireless Card Replacement: 8 단계, 이미지 3개 중 1개 Acer Aspire E3-111-C0WA Wireless Card Replacement: 8 단계, 이미지 3개 중 2개 Acer Aspire E3-111-C0WA Wireless Card Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the 6.2mm #1 Phillips head screw attaching the wireless card to the case.
    • Pull the wireless card horizontally away from the motherboard to remove it from the connector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jonathan Chandler
회원 가입일: 10/17/17
503 평판
안내서 4개를 작성함
UC Santa Barbara, Team S1-G2, Weedon Fall 2017 UC Santa Barbara, Team S1-G2, Weedon Fall 2017 회원
UCSB-WEEDON-F17S1G2
5 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 372
