주요 콘텐츠로 건너뛰기
Acer Aspire E5-471-5456 Back Replacement
필요한 것
  1. Acer Aspire E5-471-5456 Back Replacement, Back Cover: 1 단계, 이미지 1/2 Acer Aspire E5-471-5456 Back Replacement, Back Cover: 1 단계, 이미지 2/2
    • Carefully place the closed computer on a flat surface, with it oriented screen down.
    • Now you need to use the Phillips #0 Screwdriver to remove all 17 of the M2.5X8 mm screws. Use the red circles on the diagram to help you locate these screws.
  2. Acer Aspire E5-471-5456 Back Replacement: 2 단계, 이미지 1/2 Acer Aspire E5-471-5456 Back Replacement: 2 단계, 이미지 2/2
    • Use an opening tool to gently pry open the case.
    • Take extreme care when removing the case to not get the case stuck on any of the ports. Make sure that to evenly open the case and not pry one side open before the other to avoid damage.
    • Slowly peel the cover off and make sure there are no wires or clips still connecting the two pieces together. These pieces are extremely fragile so it is vital to take your time and only use light pressure.
  3. Acer Aspire E5-471-5456 Back Replacement: 3 단계, 이미지 1/1
    • Place cover and screws aside and you are now free to access the different components of this laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel Gonzalez
회원 가입일: 09/26/17
364 평판
안내서 3개 작성하였습니다
Cal Poly, Team S6-G4, Banghart Fall 2017 Cal Poly, Team S6-G4, Banghart Fall 2017 회원
CPSU-BANGHART-F17S6G4
5 회원들
안내서 6개 작성하였습니다
댓글 한 개
Thank You for the information!
jeanie49 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 6
30일 전: 16
전체 시간: 1,399
