주요 콘텐츠로 건너뛰기
Acer Aspire E5-571 Battery Replacement
필요한 것
  1. Acer Aspire E5-571 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 Battery Replacement: 2 단계, 이미지 1/1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 Battery Replacement: 3 단계, 이미지 1/1
    • Pull the battery towards you to remove it from the laptop.
결론
다른 6명이 해당 안내서를 완성하였습니다.
daniel sawyer
회원 가입일: 08/23/15
2,566 평판
안내서 5개 작성하였습니다
USF Tampa, Team 4-2, Meier Fall 2015 USF Tampa, Team 4-2, Meier Fall 2015 회원
USFT-MEIER-F15S4G2
3 회원들
안내서 5개 작성하였습니다
댓글 2개
Uh…this makes no mention of the keyboard. Why is this titled as a keyboard repair, when it simply removes the battery?
David Greene - 답글
lets hope next time the “This guide is being worked on by hardworking students. “ the steps involve more then just removing the battery
mechanimal15 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 35
전체 시간: 23,726
