주요 콘텐츠로 건너뛰기
Acer Aspire E5-571 Battery Replacement
필요한 것
  1. Acer Aspire E5-571 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
    On the E-572P the hdd and memory is accessed from the removable flap on the bottom of the laptop - do not try to take the keyboard off!
    Peter - 답글
  3. Acer Aspire E5-571 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the battery towards you to remove it from the laptop.
    A fost extrem de ușor de scos bateria Dacă toate ghidurile ar fi așa de explicite ar fi extraordinar
    Trasor - 답글
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
daniel sawyer
회원 가입일: 08/23/15
2,602 평판
안내서 5개를 작성함
USF Tampa, Team 4-2, Meier Fall 2015 USF Tampa, Team 4-2, Meier Fall 2015 회원
USFT-MEIER-F15S4G2
3 회원들
안내서 5개를 작성함
2 Guide Comments
Uh…this makes no mention of the keyboard. Why is this titled as a keyboard repair, when it simply removes the battery?
David Greene - 답글
lets hope next time the “This guide is being worked on by hardworking students. “ the steps involve more then just removing the battery
mechanimal15 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 49
전체 시간: 24,267
