주요 콘텐츠로 건너뛰기
Acer Aspire E5-571 CPU Fan Replacement
필요한 것
  1. Acer Aspire E5-571 CPU Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 CPU Fan Replacement: 2 단계, 이미지 1/1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 CPU Fan Replacement: 3 단계, 이미지 1/1
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 CPU Fan Replacement, Keyboard: 4 단계, 이미지 1/1
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 CPU Fan Replacement: 5 단계, 이미지 1/3 Acer Aspire E5-571 CPU Fan Replacement: 5 단계, 이미지 2/3 Acer Aspire E5-571 CPU Fan Replacement: 5 단계, 이미지 3/3
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips.
  6. Acer Aspire E5-571 CPU Fan Replacement: 6 단계, 이미지 1/2 Acer Aspire E5-571 CPU Fan Replacement: 6 단계, 이미지 2/2
    • Carefully flip up the white hinge. Detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
  7. Acer Aspire E5-571 CPU Fan Replacement, WiFi: 7 단계, 이미지 1/1
    • Locate the WiFi card on the motherboard.
  8. Acer Aspire E5-571 CPU Fan Replacement: 8 단계, 이미지 1/2 Acer Aspire E5-571 CPU Fan Replacement: 8 단계, 이미지 2/2
    • Locate the two antenna cables shown.
    • Using a plastic opening tool, remove both antenna cables from the WiFi card by gently prying them up.
    • Black on left. White on right.
  9. Acer Aspire E5-571 CPU Fan Replacement: 9 단계, 이미지 1/3 Acer Aspire E5-571 CPU Fan Replacement: 9 단계, 이미지 2/3 Acer Aspire E5-571 CPU Fan Replacement: 9 단계, 이미지 3/3
    • Remove this 3 mm Phillips #0 screw and the WiFi card should pop up.
    • Make sure antenna cables are removed before removing the screw.
    • Gently lift WiFi card off of the motherboard.
  10. Acer Aspire E5-571 CPU Fan Replacement, CPU Fan: 10 단계, 이미지 1/1
    • Locate the CPU Fan in the case right above the motherboard.
  11. Acer Aspire E5-571 CPU Fan Replacement: 11 단계, 이미지 1/1
    • Detach the power cable by carefully pulling on it, it will come off easily.
  12. Acer Aspire E5-571 CPU Fan Replacement: 12 단계, 이미지 1/1
    • Remove both of these 6 mm Phillips #1 screws which hold the fan onto the case.
    • Now carefully lift the fan straight up and out of its place in the case.
    • The fan should easily come right out with no trouble.
결론
다른 4명이 해당 안내서를 완성하였습니다.
daniel sawyer
회원 가입일: 08/23/15
2,566 평판
안내서 5개 작성하였습니다
USF Tampa, Team 4-2, Meier Fall 2015 USF Tampa, Team 4-2, Meier Fall 2015 회원
USFT-MEIER-F15S4G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 16
전체 시간: 4,357
