주요 콘텐츠로 건너뛰기
Acer Aspire E5-571 WiFi Replacement
필요한 것
  1. Acer Aspire E5-571 WiFi Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 WiFi Replacement: 2 단계, 이미지 1개 중 1개
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 WiFi Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 WiFi Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 WiFi Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire E5-571 WiFi Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire E5-571 WiFi Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips.
  6. Acer Aspire E5-571 WiFi Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire E5-571 WiFi Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully flip up the white hinge. Detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
  7. Acer Aspire E5-571 WiFi Replacement, WiFi: 7 단계, 이미지 1개 중 1개
    • Locate the WiFi card on the motherboard.
  8. Acer Aspire E5-571 WiFi Replacement: 8 단계, 이미지 2개 중 1개 Acer Aspire E5-571 WiFi Replacement: 8 단계, 이미지 2개 중 2개
    • Locate the two antenna cables shown.
    • Using a plastic opening tool, remove both antenna cables from the WiFi card by gently prying them up.
    • Black on left. White on right.
  9. Acer Aspire E5-571 WiFi Replacement: 9 단계, 이미지 3개 중 1개 Acer Aspire E5-571 WiFi Replacement: 9 단계, 이미지 3개 중 2개 Acer Aspire E5-571 WiFi Replacement: 9 단계, 이미지 3개 중 3개
    • Remove this 3 mm Phillips #0 screw and the WiFi card should pop up.
    • Make sure antenna cables are removed before removing the screw.
    • Gently lift WiFi card off of the motherboard.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
daniel sawyer
회원 가입일: 08/23/15
2,602 평판
안내서 5개를 작성함
USF Tampa, Team 4-2, Meier Fall 2015 USF Tampa, Team 4-2, Meier Fall 2015 회원
USFT-MEIER-F15S4G2
3 회원들
안내서 5개를 작성함
댓글 7개
Very well done - thank you!
glgsolutions - 답글
np. im glad it worked for you. could you post the exact model you have and was there anything I missed?
daniel sawyer -
Great guide. I would just like to mention a difference I found. My laptop had white connectors and the hinged lock latch was black. So I guess all assemblies aren’t identical. Also, the large connector for the keyboard did not have a locking latch. My model is an E5-571P manufactured 2014/09/15.
Dan O - 답글
Hi, I want faster Wifi. Which Wifi card do I need to replace for a Acer Aspire e15 e5-571-58E6?
Patrizia Barberio - 답글
Hi I just bought an upgrade, so I’ll tell you which one I got and if it worked when I get it in the mail in a few weeks.
Matt -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 7,723
