주요 콘텐츠로 건너뛰기
Acer Aspire E5-571-58CG CPU Fan Replacement
필요한 것
  1. Acer Aspire E5-571-58CG CPU Fan Replacement, Battery: 1 단계, 이미지 1/2 Acer Aspire E5-571-58CG CPU Fan Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG CPU Fan Replacement: 2 단계, 이미지 1/3 Acer Aspire E5-571-58CG CPU Fan Replacement: 2 단계, 이미지 2/3 Acer Aspire E5-571-58CG CPU Fan Replacement: 2 단계, 이미지 3/3
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: 3 단계, 이미지 1/3 Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: 3 단계, 이미지 2/3 Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: 3 단계, 이미지 3/3
    • Remove the top panel of the laptop with the plastic opening tool.
  4. Acer Aspire E5-571-58CG CPU Fan Replacement: 4 단계, 이미지 1/2 Acer Aspire E5-571-58CG CPU Fan Replacement: 4 단계, 이미지 2/2
    • Use a JIS #000 screw bit to remove the marked screw.
  5. Acer Aspire E5-571-58CG CPU Fan Replacement: 5 단계, 이미지 1/2 Acer Aspire E5-571-58CG CPU Fan Replacement: 5 단계, 이미지 2/2
    • Carefully pull the marked green chip out of the motherboard.
  6. Acer Aspire E5-571-58CG CPU Fan Replacement: 6 단계, 이미지 1/2 Acer Aspire E5-571-58CG CPU Fan Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to unplug the wire connecting the fan to the motherboard.
  7. Acer Aspire E5-571-58CG CPU Fan Replacement: 7 단계, 이미지 1/3 Acer Aspire E5-571-58CG CPU Fan Replacement: 7 단계, 이미지 2/3 Acer Aspire E5-571-58CG CPU Fan Replacement: 7 단계, 이미지 3/3
    • Use a JIS #00 screw bit to remove the marked screws around the CPU fan.
    • Carefully remove the CPU fan.
결론
Brendan Cuthill
회원 가입일: 10/29/18
121 평판
안내서 1개 작성함
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 UMass Dartmouth, Team S7-G7, Valliere Fall 2018 회원
UMASSD-VALLIERE-F18S7G7
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 302
