주요 콘텐츠로 건너뛰기
Acer Aspire E5-571-58CG Keyboard Replacement
필요한 것
  1. Acer Aspire E5-571-58CG Keyboard Replacement, Battery: 1 단계, 이미지 1/2 Acer Aspire E5-571-58CG Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG Keyboard Replacement: 2 단계, 이미지 1/3 Acer Aspire E5-571-58CG Keyboard Replacement: 2 단계, 이미지 2/3 Acer Aspire E5-571-58CG Keyboard Replacement: 2 단계, 이미지 3/3
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG Keyboard Replacement, Keyboard: 3 단계, 이미지 1/3 Acer Aspire E5-571-58CG Keyboard Replacement, Keyboard: 3 단계, 이미지 2/3 Acer Aspire E5-571-58CG Keyboard Replacement, Keyboard: 3 단계, 이미지 3/3
    • Make sure laptop is upright.
    • Pry the keyboard cover off with the plastic opening tool.
  4. Acer Aspire E5-571-58CG Keyboard Replacement: 4 단계, 이미지 1/3 Acer Aspire E5-571-58CG Keyboard Replacement: 4 단계, 이미지 2/3 Acer Aspire E5-571-58CG Keyboard Replacement: 4 단계, 이미지 3/3
    • Flip the keyboard cover upside down.
    • Use the JIS #000 screw bit to remove the marked M1.4 x 2 mm screws from the back of the metal panel.
  5. Acer Aspire E5-571-58CG Keyboard Replacement: 5 단계, 이미지 1/3 Acer Aspire E5-571-58CG Keyboard Replacement: 5 단계, 이미지 2/3 Acer Aspire E5-571-58CG Keyboard Replacement: 5 단계, 이미지 3/3
    • Push the metal panel forward to unlock it from plastic holders on both sides.
    • Lift the metal panel up and peel it back to expose the keyboard component.
  6. Acer Aspire E5-571-58CG Keyboard Replacement: 6 단계, 이미지 1/3 Acer Aspire E5-571-58CG Keyboard Replacement: 6 단계, 이미지 2/3 Acer Aspire E5-571-58CG Keyboard Replacement: 6 단계, 이미지 3/3
    • Use the metal spudger to lift the keyboard component out of the metal panel.
결론
Matthew Barboza
회원 가입일: 10/19/18
159 평판
안내서 1개 작성함
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 UMass Dartmouth, Team S7-G7, Valliere Fall 2018 회원
UMASSD-VALLIERE-F18S7G7
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 10
전체 시간: 459
