주요 콘텐츠로 건너뛰기
Acer Aspire E5-571-58CG Power Jack Replacement
필요한 것
  1. Acer Aspire E5-571-58CG Power Jack Replacement, Battery: 1 단계, 이미지 1/2 Acer Aspire E5-571-58CG Power Jack Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG Power Jack Replacement: 2 단계, 이미지 1/3 Acer Aspire E5-571-58CG Power Jack Replacement: 2 단계, 이미지 2/3 Acer Aspire E5-571-58CG Power Jack Replacement: 2 단계, 이미지 3/3
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: 3 단계, 이미지 1/3 Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: 3 단계, 이미지 2/3 Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: 3 단계, 이미지 3/3
    • Remove the top panel of the laptop with the plastic opening tool.
  4. Acer Aspire E5-571-58CG Power Jack Replacement: 4 단계, 이미지 1/2 Acer Aspire E5-571-58CG Power Jack Replacement: 4 단계, 이미지 2/2
    • Remove the plastic safeguard from the CD drive slot.
  5. Acer Aspire E5-571-58CG Power Jack Replacement: 5 단계, 이미지 1/3 Acer Aspire E5-571-58CG Power Jack Replacement: 5 단계, 이미지 2/3 Acer Aspire E5-571-58CG Power Jack Replacement: 5 단계, 이미지 3/3
    • Remove the marked screws with the JIS #00 screwdriver.
  6. Acer Aspire E5-571-58CG Power Jack Replacement: 6 단계, 이미지 1/2 Acer Aspire E5-571-58CG Power Jack Replacement: 6 단계, 이미지 2/2
    • Disconnect the opposite end of the power jack from the motherboard by carefully pulling the wire.
  7. Acer Aspire E5-571-58CG Power Jack Replacement: 7 단계, 이미지 1/2 Acer Aspire E5-571-58CG Power Jack Replacement: 7 단계, 이미지 2/2
    • Lift the bottom right side of the screen to move the metal plate covering the power jack.
  8. Acer Aspire E5-571-58CG Power Jack Replacement: 8 단계, 이미지 1/2 Acer Aspire E5-571-58CG Power Jack Replacement: 8 단계, 이미지 2/2
    • Carefully lift the power jack out of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Aliana Johnson
회원 가입일: 10/24/18
145 평판
안내서 1개 작성함
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 UMass Dartmouth, Team S7-G7, Valliere Fall 2018 회원
UMASSD-VALLIERE-F18S7G7
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 1,259
