주요 콘텐츠로 건너뛰기
Acer Aspire E5-571-58CG Touchpad Replacement
필요한 것
  1. Acer Aspire E5-571-58CG Touchpad Replacement, Keyboard: 1 단계, 이미지 1/3 Acer Aspire E5-571-58CG Touchpad Replacement, Keyboard: 1 단계, 이미지 2/3 Acer Aspire E5-571-58CG Touchpad Replacement, Keyboard: 1 단계, 이미지 3/3
    • Make sure laptop is upright.
    • Pry the keyboard cover off with the plastic opening tool.
  2. Acer Aspire E5-571-58CG Touchpad Replacement: 2 단계, 이미지 1/3 Acer Aspire E5-571-58CG Touchpad Replacement: 2 단계, 이미지 2/3 Acer Aspire E5-571-58CG Touchpad Replacement: 2 단계, 이미지 3/3
    • Flip the keyboard cover upside down.
    • Use the JIS #000 screw bit to remove the marked M1.4 x 2 mm screws from the back of the metal panel.
  3. Acer Aspire E5-571-58CG Touchpad Replacement: 3 단계, 이미지 1/3 Acer Aspire E5-571-58CG Touchpad Replacement: 3 단계, 이미지 2/3 Acer Aspire E5-571-58CG Touchpad Replacement: 3 단계, 이미지 3/3
    • Push the metal panel forward to unlock it from plastic holders on both sides.
    • Lift the metal panel up and peel it back to expose the keyboard component.
  4. Acer Aspire E5-571-58CG Touchpad Replacement: 4 단계, 이미지 1/3 Acer Aspire E5-571-58CG Touchpad Replacement: 4 단계, 이미지 2/3 Acer Aspire E5-571-58CG Touchpad Replacement: 4 단계, 이미지 3/3
    • Use the metal spudger to lift the keyboard component out of the metal panel.
  5. Acer Aspire E5-571-58CG Touchpad Replacement, Touchpad: 5 단계, 이미지 1/2 Acer Aspire E5-571-58CG Touchpad Replacement, Touchpad: 5 단계, 이미지 2/2
    • Make sure you have removed the keyboard before attempting to remove the touchpad.
    • Use a 1 1/2 mm flathead screw bit to remove the black screw at the bottom of the panel.
  6. Acer Aspire E5-571-58CG Touchpad Replacement: 6 단계, 이미지 1/3 Acer Aspire E5-571-58CG Touchpad Replacement: 6 단계, 이미지 2/3 Acer Aspire E5-571-58CG Touchpad Replacement: 6 단계, 이미지 3/3
    • Peel back the marked strips with the metal spudger.
  7. Acer Aspire E5-571-58CG Touchpad Replacement: 7 단계, 이미지 1/3 Acer Aspire E5-571-58CG Touchpad Replacement: 7 단계, 이미지 2/3 Acer Aspire E5-571-58CG Touchpad Replacement: 7 단계, 이미지 3/3
    • Use a 1 1/2 mm flathead screw bit to remove the two black screws at the top of the panel.
  8. Acer Aspire E5-571-58CG Touchpad Replacement: 8 단계, 이미지 1/2 Acer Aspire E5-571-58CG Touchpad Replacement: 8 단계, 이미지 2/2
    • Lift the touch pad out of the metal panel with a metal spudger.
결론
Daniel Mello
회원 가입일: 10/16/18
258 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 UMass Dartmouth, Team S7-G7, Valliere Fall 2018 회원
UMASSD-VALLIERE-F18S7G7
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 1,235
