주요 콘텐츠로 건너뛰기
Acer Aspire E5-571P-55TL Hard Drive Replacement
필요한 것
  1. Acer Aspire E5-571P-55TL Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure that laptop is turned off.
    • Turn the laptop upside down with the battery facing you.
  2. Acer Aspire E5-571P-55TL Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
  3. Acer Aspire E5-571P-55TL Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire E5-571P-55TL Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571P-55TL Hard Drive Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 Acer Aspire E5-571P-55TL Hard Drive Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
  5. Acer Aspire E5-571P-55TL Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire E5-571P-55TL Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire E5-571P-55TL Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully place your fingers underneath the top of the keyboard just below the screen.
    • Pull upwards until you can hear the keyboard click out of place.
    • Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
    • Don't pull the keyboard off the frame yet because it's attached by ribbon connectors.
    • After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
  6. Acer Aspire E5-571P-55TL Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, remove the two 8 mm screws holding the hard drive carriage in place.
  7. Acer Aspire E5-571P-55TL Hard Drive Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire E5-571P-55TL Hard Drive Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully unplug the ribbon cable running across the hard drive carriage and place it to the side.
    • Remove the hard drive by sliding it to your right, away from the motherboard, next pull the hard drive towards yourself and away from the laptop.
  8. Acer Aspire E5-571P-55TL Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Once again using a Phillips #0 screwdriver, remove the two 3 mm screws highlighted on each side of the hard drive case.
    • Open the hard drive case to replace the hard drive.
결론
작성자
3다른 기여자 명과 함께
Zebediah Perkins
회원 가입일: 03/27/22
112 평판
안내서 1개를 작성함
UMass Dartmouth, Team B-1, Gurgel Spring 2022 UMass Dartmouth, Team B-1, Gurgel Spring 2022 회원
UMASSD-GURGEL-S22SBG1
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 12
전체 시간: 295
