주요 콘텐츠로 건너뛰기
Acer Aspire E5-571P-55TL Keyboard Replacement
필요한 것
  1. Acer Aspire E5-571P-55TL Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure that laptop is turned off.
    • Turn the laptop upside down with the battery facing you.
  2. Acer Aspire E5-571P-55TL Keyboard Replacement: 2 단계, 이미지 1/1
    • Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
  3. Acer Aspire E5-571P-55TL Keyboard Replacement: 3 단계, 이미지 1/2 Acer Aspire E5-571P-55TL Keyboard Replacement: 3 단계, 이미지 2/2
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571P-55TL Keyboard Replacement, Keyboard: 4 단계, 이미지 1/2 Acer Aspire E5-571P-55TL Keyboard Replacement, Keyboard: 4 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
  5. Acer Aspire E5-571P-55TL Keyboard Replacement: 5 단계, 이미지 1/3 Acer Aspire E5-571P-55TL Keyboard Replacement: 5 단계, 이미지 2/3 Acer Aspire E5-571P-55TL Keyboard Replacement: 5 단계, 이미지 3/3
    • Carefully place your fingers underneath the top of the keyboard just below the screen.
    • Pull upwards until you can hear the keyboard click out of place.
    • Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
    • Don't pull the keyboard off the frame yet because it's attached by ribbon connectors.
    • After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
결론
Melvin Baptista
회원 가입일: 03/28/22
135 평판
안내서 1개 작성함
UMass Dartmouth, Team B-1, Gurgel Spring 2022 UMass Dartmouth, Team B-1, Gurgel Spring 2022 회원
UMASSD-GURGEL-S22SBG1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 6
전체 시간: 157
