주요 콘텐츠로 건너뛰기
Acer Aspire E5-573G Battery Replacement
필요한 것
  1. Acer Aspire E5-573G Battery Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Ensure your device is OFF before beginning this procedure.
    • Unscrew the 5 mm Phillips head screw holding the drive in place.
  2. Acer Aspire E5-573G Battery Replacement: 2 단계, 이미지 1/1
    • Pull out the disk drive.
  3. Acer Aspire E5-573G Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Unscrew the seventeen 5 mm Phillips head screws from the bottom cover.
  4. Acer Aspire E5-573G Battery Replacement: 4 단계, 이미지 1/1
    • Unscrew the three 2.5 mm Phillips head screws underneath the optical drive bay.
  5. Acer Aspire E5-573G Battery Replacement: 5 단계, 이미지 1/1
    • Run a pick between the bottom cover and the device around the edge of the laptop and unclip the cover from the rest of the device.
  6. Acer Aspire E5-573G Battery Replacement: 6 단계, 이미지 1/1
    • Lift the left side of the bottom cover, but do not completely remove the cover, as the speaker is cable is still connected and will be damaged.
    • Pull the speaker connector towards the fan to disconnect it from its socket on the motherboard.
  7. Acer Aspire E5-573G Battery Replacement: 7 단계, 이미지 1/1
    • Pull the battery connector towards the battery to disconnect it from its socket on the motherboard.
    • Remove the battery.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Alex Bahm
회원 가입일: 01/18/18
2,226 평판
안내서 6개 작성하였습니다
Cal Poly, Team S12-G5, Banghart Winter 2018 Cal Poly, Team S12-G5, Banghart Winter 2018 회원
CPSU-BANGHART-W18S12G5
2 회원들
안내서 15개 작성하였습니다
댓글 한 개
Where can i buy a battery replacement for my aspire e5-573g-59c3?
mfortich98 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 71
전체 시간: 21,625
