주요 콘텐츠로 건너뛰기
Acer Aspire E5-575G-39HV Keyboard Replacement
필요한 것
  1. Acer Aspire E5-575G-39HV Keyboard Replacement, Opening the back panel: 1 단계, 이미지 3개 중 1개 Acer Aspire E5-575G-39HV Keyboard Replacement, Opening the back panel: 1 단계, 이미지 3개 중 2개 Acer Aspire E5-575G-39HV Keyboard Replacement, Opening the back panel: 1 단계, 이미지 3개 중 3개
    • Unscrew all 16 screws holding the back panel.
    • Open the HDD, SSD and RAM cover and unscrew all visible screws that hold the panel. Now is a good idea to upgrade those parts if you want.
    • Use a prying tool to separate the top and bottom pieces.
  2. Acer Aspire E5-575G-39HV Keyboard Replacement, The insides.: 2 단계, 이미지 2개 중 1개 Acer Aspire E5-575G-39HV Keyboard Replacement, The insides.: 2 단계, 이미지 2개 중 2개
    • Disconnect all visible connectors, starting with the battery (Yellow), they the other ones (Blue). After that remove the screws attaching the motherboard to the panel.
    • After that remove the black protective film, without damaging it. Now the keyboard should be revealed.
  3. Acer Aspire E5-575G-39HV Keyboard Replacement, Removing the display.: 3 단계, 이미지 3개 중 1개 Acer Aspire E5-575G-39HV Keyboard Replacement, Removing the display.: 3 단계, 이미지 3개 중 2개 Acer Aspire E5-575G-39HV Keyboard Replacement, Removing the display.: 3 단계, 이미지 3개 중 3개
    • Remove the screws that hold the display hinges and detach the display.
  4. Acer Aspire E5-575G-39HV Keyboard Replacement, Removing the old keyboard.: 4 단계, 이미지 3개 중 1개 Acer Aspire E5-575G-39HV Keyboard Replacement, Removing the old keyboard.: 4 단계, 이미지 3개 중 2개 Acer Aspire E5-575G-39HV Keyboard Replacement, Removing the old keyboard.: 4 단계, 이미지 3개 중 3개
    • Use a soldering iron with a big tip, to melt the plastic rivets that hold the metal case for the keyboard.
    • Use a prying tool the remove the metal case.
    • Remove the old keyboard, place the new one and dont forget to place the metal case on top of it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Simeon Brankov
회원 가입일: 11/08/20
8,432 평판
안내서 62개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 46
전체 시간: 1,272
