주요 콘텐츠로 건너뛰기
Acer Aspire E5-721-64T8 Motherboard Replacement
필요한 것
  1. Acer Aspire E5-721-64T8  Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
  2. Acer Aspire E5-721-64T8  Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, lift up on the side opposite of the Ethernet connector.
    • With the plastic opening tool under the bottom panel, work your way around the perimeter until the panel separates.
  3. Acer Aspire E5-721-64T8  Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two 6mm Phillips #0 screws from the battery.
  4. Acer Aspire E5-721-64T8  Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire E5-721-64T8  Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery from the motherboard.
    • Pull the battery up and out of the laptop.
  5. Acer Aspire E5-721-64T8  Motherboard Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 Acer Aspire E5-721-64T8  Motherboard Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Remove the two 6mm Phillips #0 screws from the fan.
    • Disconnect the fan from the motherboard.
    • Remove the four 6mm Phillips #0 screws from the heat sink.
    • Lift and remove the heatsink assembly from laptop.
  6. Acer Aspire E5-721-64T8  Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the Wi-Fi card by pulling it from the motherboard socket.
  7. Acer Aspire E5-721-64T8  Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the display cable from the motherboard.
  8. Acer Aspire E5-721-64T8  Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the speaker from the motherboard.
  9. Acer Aspire E5-721-64T8  Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire E5-721-64T8  Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
  10. Acer Aspire E5-721-64T8  Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Acer Aspire E5-721-64T8  Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Use a spudger to flip up the retaining flap on the black ribbon cable ZIF socket.
  11. Acer Aspire E5-721-64T8  Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the motherboard up from the narrow side and jiggle slightly so that way it doesn't get caught on the ports of the laptop case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jamie Kleinkopf
회원 가입일: 01/28/18
228 평판
안내서 1개를 작성함
USF Tampa, Team S7-G3, Passmore Spring 2018 USF Tampa, Team S7-G3, Passmore Spring 2018 회원
USFT-PASSMORE-S18S7G3
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 17
전체 시간: 831
