주요 콘텐츠로 건너뛰기
Acer Aspire E5-721-64T8 Touch Pad Replacement
필요한 것
  1. Acer Aspire E5-721-64T8 Touch Pad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
  2. Acer Aspire E5-721-64T8 Touch Pad Replacement: 2 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, lift up on the side opposite of the Ethernet connector.
    • With the plastic opening tool under the bottom panel, work your way around the perimeter until the panel separates.
  3. Acer Aspire E5-721-64T8 Touch Pad Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two 6mm Phillips #0 screws from the battery.
  4. Acer Aspire E5-721-64T8 Touch Pad Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire E5-721-64T8 Touch Pad Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery from the motherboard.
    • Pull the battery up and out of the laptop.
  5. Acer Aspire E5-721-64T8 Touch Pad Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 Acer Aspire E5-721-64T8 Touch Pad Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Remove the two 6mm Phillips #0 screws from the fan.
    • Disconnect the fan from the motherboard.
    • Remove the four 6mm Phillips #0 screws from the heat sink.
    • Lift and remove the heatsink assembly from laptop.
  6. Acer Aspire E5-721-64T8 Touch Pad Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the Wi-Fi card by pulling it from the motherboard socket.
  7. Acer Aspire E5-721-64T8 Touch Pad Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the display cable from the motherboard.
  8. Acer Aspire E5-721-64T8 Touch Pad Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the speaker from the motherboard.
  9. Acer Aspire E5-721-64T8 Touch Pad Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire E5-721-64T8 Touch Pad Replacement: 9 단계, 이미지 2개 중 2개
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
  10. Acer Aspire E5-721-64T8 Touch Pad Replacement: 10 단계, 이미지 2개 중 1개 Acer Aspire E5-721-64T8 Touch Pad Replacement: 10 단계, 이미지 2개 중 2개
    • Use a spudger to flip up the retaining flap on the black ribbon cable ZIF socket.
  11. Acer Aspire E5-721-64T8 Touch Pad Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the motherboard up from the narrow side and jiggle slightly so that way it doesn't get caught on the ports of the laptop case.
  12. Acer Aspire E5-721-64T8 Touch Pad Replacement, Touch Pad: 12 단계, 이미지 1개 중 1개
    • Peel the black adhesive film up.
  13. Acer Aspire E5-721-64T8 Touch Pad Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the three 6mm Phillips #0 screws from touchpad.
  14. Acer Aspire E5-721-64T8 Touch Pad Replacement: 14 단계, 이미지 1개 중 1개
    • Use a spudger to flip up the retaining flap on the touchpad ribbon cable ZIF socket.
    • Remove the ribbon cable from the ZIF socket.
  15. Acer Aspire E5-721-64T8 Touch Pad Replacement: 15 단계, 이미지 2개 중 1개 Acer Aspire E5-721-64T8 Touch Pad Replacement: 15 단계, 이미지 2개 중 2개
    • Lift the touchpad up by the side closest to the middle of the laptop and pull up towards you to remove.
결론
작성자
2다른 기여자 명과 함께
Ed Herrera
회원 가입일: 01/25/18
390 평판
안내서 3개를 작성함
USF Tampa, Team S7-G3, Passmore Spring 2018 USF Tampa, Team S7-G3, Passmore Spring 2018 회원
USFT-PASSMORE-S18S7G3
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 332
