주요 콘텐츠로 건너뛰기
Acer Aspire ES1-512-C80E Disk Drive Replacement
필요한 것
  1. Acer Aspire ES1-512-C80E Disk Drive Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Disk Drive Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire ES1-512-C80E Disk Drive Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire ES1-512-C80E Disk Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E Disk Drive Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire ES1-512-C80E Disk Drive Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire ES1-512-C80E Disk Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E Disk Drive Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire ES1-512-C80E Disk Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E Disk Drive Replacement: 6 단계, 이미지 1개 중 1개
    • The keyboard is removed and ready to be replaced.
  7. Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: 7 단계, 이미지 3개 중 1개 Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: 7 단계, 이미지 3개 중 2개 Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: 7 단계, 이미지 3개 중 3개
    • Push the disk drive out of the side slot.
결론
To reassemble your device, follow the steps in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Peter Bulman
회원 가입일: 10/31/19
237 평판
안내서 1개를 작성함
UMass Dartmouth, Team S2-G8, Barthe Fall 2019 UMass Dartmouth, Team S2-G8, Barthe Fall 2019 회원
UMASSD-BARTHE-F19S2G8
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 627
