주요 콘텐츠로 건너뛰기
Acer Aspire ES1-512-C80E Fan Replacement
필요한 것
  1. Acer Aspire ES1-512-C80E Fan Replacement, Back Cover: 1 단계, 이미지 1/1
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Fan Replacement: 2 단계, 이미지 1/3 Acer Aspire ES1-512-C80E Fan Replacement: 2 단계, 이미지 2/3 Acer Aspire ES1-512-C80E Fan Replacement: 2 단계, 이미지 3/3
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Fan Replacement, Keyboard: 3 단계, 이미지 1/3 Acer Aspire ES1-512-C80E Fan Replacement, Keyboard: 3 단계, 이미지 2/3 Acer Aspire ES1-512-C80E Fan Replacement, Keyboard: 3 단계, 이미지 3/3
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E Fan Replacement: 4 단계, 이미지 1/3 Acer Aspire ES1-512-C80E Fan Replacement: 4 단계, 이미지 2/3 Acer Aspire ES1-512-C80E Fan Replacement: 4 단계, 이미지 3/3
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E Fan Replacement: 5 단계, 이미지 1/2 Acer Aspire ES1-512-C80E Fan Replacement: 5 단계, 이미지 2/2
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E Fan Replacement: 6 단계, 이미지 1/1
    • The keyboard is removed and ready to be replaced.
  7. Acer Aspire ES1-512-C80E Fan Replacement, Fan: 7 단계, 이미지 1/2 Acer Aspire ES1-512-C80E Fan Replacement, Fan: 7 단계, 이미지 2/2
    • Remove twelve 1.2mm Phillips #000 screws from the motherboard, wireless LAN card, and hard drive.
  8. Acer Aspire ES1-512-C80E Fan Replacement: 8 단계, 이미지 1/3 Acer Aspire ES1-512-C80E Fan Replacement: 8 단계, 이미지 2/3 Acer Aspire ES1-512-C80E Fan Replacement: 8 단계, 이미지 3/3
    • Using a Phillips #000 screwdriver, remove both 1.2mm screws that hold the fan in place.
  9. Acer Aspire ES1-512-C80E Fan Replacement: 9 단계, 이미지 1/3 Acer Aspire ES1-512-C80E Fan Replacement: 9 단계, 이미지 2/3 Acer Aspire ES1-512-C80E Fan Replacement: 9 단계, 이미지 3/3
    • Lift the fan, hard drive, motherboard, and wireless LAN card out of the device.
    • These components are still connected with wires. Remove all plugs that may be attached to other components in order to isolate the group of components.
  10. Acer Aspire ES1-512-C80E Fan Replacement: 10 단계, 이미지 1/1
    • Flip over the motherboard.
    • Remove all three 1.2mm Phillips #00 screws that attach the fan to the motherboard.
  11. Acer Aspire ES1-512-C80E Fan Replacement: 11 단계, 이미지 1/3 Acer Aspire ES1-512-C80E Fan Replacement: 11 단계, 이미지 2/3 Acer Aspire ES1-512-C80E Fan Replacement: 11 단계, 이미지 3/3
    • The fan and motherboard are still connected with wires. Remove any plugs that may be attaching the components
    • Remove the fan from the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Robert Creighton
회원 가입일: 10/31/19
682 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S2-G8, Barthe Fall 2019 UMass Dartmouth, Team S2-G8, Barthe Fall 2019 회원
UMASSD-BARTHE-F19S2G8
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 13
전체 시간: 404
