주요 콘텐츠로 건너뛰기
Acer Aspire ES1-512-C96S Battery Replacement
필요한 것
  1. Acer Aspire ES1-512-C96S Battery Replacement, Removing the Screws and Opening it Up: 1 단계, 이미지 3개 중 1개 Acer Aspire ES1-512-C96S Battery Replacement, Removing the Screws and Opening it Up: 1 단계, 이미지 3개 중 2개 Acer Aspire ES1-512-C96S Battery Replacement, Removing the Screws and Opening it Up: 1 단계, 이미지 3개 중 3개
    • Place the device upside down on a flat, soft surface.
    • Using a Phillips #0 screwdriver, remove all 18 screws that secure the bottom cover of the device.
    • Once all screws are removed, flip laptop back over and open it.
    • Begin prying in the corners and use a spluger to pry around the edge. Hearing popping noises from the plastic is normal.
  2. Acer Aspire ES1-512-C96S Battery Replacement, Lifting Keyboard: 2 단계, 이미지 2개 중 1개 Acer Aspire ES1-512-C96S Battery Replacement, Lifting Keyboard: 2 단계, 이미지 2개 중 2개
    • Lift Slowly, once you have popped all the plastic off the bottom case. Do not lift off completely
    • There are 2 ribbon cables are connecting the keyboard and Touch pad to the Motherboard.
  3. Acer Aspire ES1-512-C96S Battery Replacement, Disconnecting Keyboard and Touchpad Cables: 3 단계, 이미지 3개 중 1개 Acer Aspire ES1-512-C96S Battery Replacement, Disconnecting Keyboard and Touchpad Cables: 3 단계, 이미지 3개 중 2개 Acer Aspire ES1-512-C96S Battery Replacement, Disconnecting Keyboard and Touchpad Cables: 3 단계, 이미지 3개 중 3개
    • Locate the lock for the larger Ribbon cable on the sides of the cable. Slide them back, Gently, until they release the cable. The lock may fall off, that's okay. It will reattach.
    • Notice the lock bar is off of the connector.
    • The smaller ribbon cable has a latch, that is pulled upward, gently, until it disengages.
    • Now the Keyboard should remove completely.
  4. Acer Aspire ES1-512-C96S Battery Replacement, Removing Battery from locks: 4 단계, 이미지 3개 중 1개 Acer Aspire ES1-512-C96S Battery Replacement, Removing Battery from locks: 4 단계, 이미지 3개 중 2개 Acer Aspire ES1-512-C96S Battery Replacement, Removing Battery from locks: 4 단계, 이미지 3개 중 3개
    • Disconnect the Battery from the Motherboard and there is 1 screw, PH0, that is holding the battery in place.
    • There are also several tabs that are holding the battery in place. Bend the tabs down slightly, just enough to disengage them.
    • Once all locking tabs have been moved, lift from bottom and pull out.
결론
작성자
1다른 기여자 명과 함께
Zelik Cosio-Altamirano
회원 가입일: 04/23/21
153 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 40
전체 시간: 931
