주요 콘텐츠로 건너뛰기
Acer Aspire ES1-711-P1UV Fan Replacement
필요한 것
  1. Acer Aspire ES1-711-P1UV Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Fan Replacement: 2 단계, 이미지 1/1
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Fan Replacement: 3 단계, 이미지 1/1
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Fan Replacement: 4 단계, 이미지 1/1
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
  5. Acer Aspire ES1-711-P1UV Fan Replacement, Fan: 5 단계, 이미지 1/1
    • Locate and remove the 5 mm screw using the Phillips #0 screwdriver.
    • Unscrew the four 5mm screws still holding down the fan.
    • The four 5mm screws in the second part of this step cannot be fully removed from the fan. Loosen them and continue on to Step 6.
  6. Acer Aspire ES1-711-P1UV Fan Replacement: 6 단계, 이미지 1/3 Acer Aspire ES1-711-P1UV Fan Replacement: 6 단계, 이미지 2/3 Acer Aspire ES1-711-P1UV Fan Replacement: 6 단계, 이미지 3/3
    • Disconnect the red, white, black, and yellow bundled cable connectors from the motherboard by gently pulling them.
    • Remove the fan assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lindsay O'Shea
회원 가입일: 03/22/18
414 평판
안내서 3개 작성하였습니다
Sam Houston State, Team S17-G3, Blackburne Spring 2018 Sam Houston State, Team S17-G3, Blackburne Spring 2018 회원
SHSU-BLACKBURNE-S18S17G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 640
