주요 콘텐츠로 건너뛰기
Acer Aspire ES1-711-P1UV Screen Replacement
필요한 것
  1. Acer Aspire ES1-711-P1UV Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
  5. Acer Aspire ES1-711-P1UV Screen Replacement, Screen: 5 단계, 이미지 2개 중 1개 Acer Aspire ES1-711-P1UV Screen Replacement, Screen: 5 단계, 이미지 2개 중 2개
    • Place the laptop on a flat surface and open it to see the screen.
    • Using your fingers or a plastic opening tool, pry open the bezel that holds the screen in place.
  6. Acer Aspire ES1-711-P1UV Screen Replacement: 6 단계, 이미지 3개 중 1개 Acer Aspire ES1-711-P1UV Screen Replacement: 6 단계, 이미지 3개 중 2개 Acer Aspire ES1-711-P1UV Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Use the Phillips #0 screwdriver to remove the fourteen 5mm screws around the screen.
    • Use the Phillips #0 screwdriver to remove the four 4mm screws holding in the screen.
    • Before unscrewing the screen, place a paper on the keyboard to protect the screen from scratches.
  7. Acer Aspire ES1-711-P1UV Screen Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire ES1-711-P1UV Screen Replacement: 7 단계, 이미지 2개 중 2개
    • With the screen on the paper, detach the Zero Insertion Force (ZIF) connector attaching the screen to the video cable inside of the front cover.
    • To remove the ZIF use your finger to flip up the top cover and gently pull the cable out.
    • Be sure to pry open the hinged flap not the connector socket
    • Gently remove the screen from laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Camille Ingham
회원 가입일: 03/22/18
445 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 18
전체 시간: 1,023
