주요 콘텐츠로 건너뛰기
Acer Aspire M5-583P-6423 Hard Drive Replacement
필요한 것
  1. Acer Aspire M5-583P-6423 Hard Drive Replacement, Battery: 1 단계, 이미지 1/3 Acer Aspire M5-583P-6423 Hard Drive Replacement, Battery: 1 단계, 이미지 2/3 Acer Aspire M5-583P-6423 Hard Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Turn the computer off and close it. Disconnect the charging cable from the laptop and place the laptop upside down.
    • Remove seventeen M2.5x8mm screws on the back cover of the laptop with the Phillips #00 screwdriver.
  2. Acer Aspire M5-583P-6423 Hard Drive Replacement: 2 단계, 이미지 1/2 Acer Aspire M5-583P-6423 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Push the back cover up from each side using the iFixit opening tool.
    • You’ll hear a popping sound as you lift the back cover.
    • Once the back cover is separated, you’ll see all the internal components of the laptop.
  3. Acer Aspire M5-583P-6423 Hard Drive Replacement: 3 단계, 이미지 1/2 Acer Aspire M5-583P-6423 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Pull the rainbow cord out by using the iFixit opening tool on each side of its connecting slot.
    • This step can be done by using your fingers, but its highly recommended to use the iFixit removal tool instead.
  4. Acer Aspire M5-583P-6423 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Remove the M2.5 x 3mm screw that holds down the battery using the Phillips #00 screwdriver.
  5. Acer Aspire M5-583P-6423 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Lift the battery up from its edges and pull back slightly towards the hinges to remove the battery.
    • The battery is now detached from the laptop and can be set aside.
  6. Acer Aspire M5-583P-6423 Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1/1
    • Remove two M2x3mm screws by using the Phillips #00 Screwdriver.
  7. Acer Aspire M5-583P-6423 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Lift the hard drive and grip the gray housing from the sides. Then, pull apart the hard drive and the housing.
    • Do not pull on the cord. Doing so repetitively will damage it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ty Bulot
회원 가입일: 01/14/20
446 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 677
