주요 콘텐츠로 건너뛰기
소개
The first step will be to remove all the screws from the back cover of the device. Then we will remove the back cover. Next, we will remove the screw holding the battery in place. Once that is complete the battery will be unplugged and removed. These steps will be repeated in reverse to put everything back together.
  1. Remove all 18 marked screws (2.12 mm) using a Phillips #1 Screwdriver.
    • Remove all 18 marked screws (2.12 mm) using a Phillips #1 Screwdriver.
  2. Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off. Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
    • Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
  3. Remove the 1 marked screw (3.3 mm) holding the battery in place using a Phillips #1 Screwdriver. Remove the 1 marked screw (3.3 mm) holding the battery in place using a Phillips #1 Screwdriver.
    • Remove the 1 marked screw (3.3 mm) holding the battery in place using a Phillips #1 Screwdriver.
  4. Unplug the marked plug from the motherboard and this will complete the removal of the battery. Unplug the marked plug from the motherboard and this will complete the removal of the battery.
    • Unplug the marked plug from the motherboard and this will complete the removal of the battery.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Daniel Bates
회원 가입일: 2018년 01월 29일
172 평판
안내서 1개 작성함
University of Alabama, Team S1-G4, Bedsole Spring 2018 University of Alabama, Team S1-G4, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 28
전체 시간: 1,867
