주요 콘텐츠로 건너뛰기
Acer Aspire M5-583P-9688 Hard Drive Replacement
필요한 것
  1. Acer Aspire M5-583P-9688 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Remove the 18 marked screws (2.12 mm) using a Phillips #1 head screwdriver.
  2. Acer Aspire M5-583P-9688 Hard Drive Replacement: 2 단계, 이미지 1/2 Acer Aspire M5-583P-9688 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
  3. Acer Aspire M5-583P-9688 Hard Drive Replacement: 3 단계, 이미지 1/2 Acer Aspire M5-583P-9688 Hard Drive Replacement: 3 단계, 이미지 2/2
    • This particular laptop does not have a hard drive. The red rectangle is where your hard drive will be.
    • To remove the hard drive, carefully take it out of the brackets holding it in place. Once you have it out of the brackets, remove the connector from the hard drive.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Collin Steel
회원 가입일: 01/29/18
328 평판
안내서 2개 작성하였습니다
University of Alabama, Team S1-G4, Bedsole Spring 2018 University of Alabama, Team S1-G4, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 1,571
