주요 콘텐츠로 건너뛰기
Acer Aspire One 532h-2527 Hard Disk Drive Replacement
필요한 것
  1. Acer Aspire One 532h-2527 Hard Disk Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Press the power button to turn off the netbook.
  2. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 2 단계, 이미지 1/1
    • Place the netbook bottom-side-up on a flat surface.
    • Locate the unlock latch on the top right corner of the back.
  3. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 3 단계, 이미지 1/1
    • To unlock the battery, slide the lock latch in the direction indicated by the unlocking icon. You should see the orange indicator which means that the latch is unlocked.
  4. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 4 단계, 이미지 1/3 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 4 단계, 이미지 2/3 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 4 단계, 이미지 3/3
    • On the opposite side, slide and hold the release latch.
    • Gently slide the battery out.
  5. Acer Aspire One 532h-2527 Hard Disk Drive Replacement, Back Plate: 5 단계, 이미지 1/1
    • Use a #0 Phillips screwdriver to remove the three 6mm screws from the larger back plate.
  6. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 6 단계, 이미지 1/1
    • Use the plastic opening tool on the recessed notch at the bottom of the larger plate to gently lift the plate.
  7. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 7 단계, 이미지 1/1
    • Once the plate becomes unhinged, gently rotate the plate to take it off of the device.
  8. Acer Aspire One 532h-2527 Hard Disk Drive Replacement, Hard Disk Drive: 8 단계, 이미지 1/1
    • Locate the HDD after the back plate is removed. It will be the large rectangle that takes up most of the space.
  9. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 9 단계, 이미지 1/2 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 9 단계, 이미지 2/2
    • Gently press down on the HDD and slide it to the left as far as it will go.
  10. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 10 단계, 이미지 1/2 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 10 단계, 이미지 2/2
    • Grab the edges of the HDD, slightly rotate it, and gently pull it out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Erica Romero
회원 가입일: 09/15/16
481 평판
안내서 2개 작성하였습니다
USF Tampa, Team 11-6, Blackwell Fall 2016 USF Tampa, Team 11-6, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G6
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 1,671
