주요 콘텐츠로 건너뛰기
Acer Aspire One 532h-2527 Keyboard Replacement
필요한 것
  1. Acer Aspire One 532h-2527 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Press the power button to turn off the netbook.
  2. Acer Aspire One 532h-2527 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Place the netbook bottom-side-up on a flat surface.
    • Locate the unlock latch on the top right corner of the back.
  3. Acer Aspire One 532h-2527 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • To unlock the battery, slide the lock latch in the direction indicated by the unlocking icon. You should see the orange indicator which means that the latch is unlocked.
  4. Acer Aspire One 532h-2527 Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire One 532h-2527 Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire One 532h-2527 Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • On the opposite side, slide and hold the release latch.
    • Gently slide the battery out.
  5. Acer Aspire One 532h-2527 Keyboard Replacement, Keyboard: 5 단계, 이미지 1개 중 1개
    • Locate the three latches along the top crevice along the top rows of keys and the plastic boarder.
  6. Acer Aspire One 532h-2527 Keyboard Replacement: 6 단계, 이미지 3개 중 1개 Acer Aspire One 532h-2527 Keyboard Replacement: 6 단계, 이미지 3개 중 2개 Acer Aspire One 532h-2527 Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Using the metal spudger, gently pry each tab releasing the keyboard. Make sure as you move to each new one that the previous one does not reset itself.
  7. Acer Aspire One 532h-2527 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Check for tabs on the side of the keyboard.
    • If there are no tabs lift the top of the keyboard.
  8. Acer Aspire One 532h-2527 Keyboard Replacement: 8 단계, 이미지 3개 중 1개 Acer Aspire One 532h-2527 Keyboard Replacement: 8 단계, 이미지 3개 중 2개 Acer Aspire One 532h-2527 Keyboard Replacement: 8 단계, 이미지 3개 중 3개
    • Locate the sticker-like connecter on the back of the keyboard. Carefully unplug it.
  9. Acer Aspire One 532h-2527 Keyboard Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire One 532h-2527 Keyboard Replacement: 9 단계, 이미지 2개 중 2개
    • Remove keyboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jair Burgos
회원 가입일: 09/15/16
425 평판
안내서 3개를 작성함
USF Tampa, Team 11-6, Blackwell Fall 2016 USF Tampa, Team 11-6, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G6
3 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 727
