주요 콘텐츠로 건너뛰기
Acer Aspire One 532h-2806 Keyboard Replacement
필요한 것
  1. Acer Aspire One 532h-2806 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Make sure the laptop is turned off and the battery is removed.
    • Above the top row of the keys, locate three plastic latches.
  2. Acer Aspire One 532h-2806 Keyboard Replacement: 2 단계, 이미지 1/1
    • Use the medal spudger to press each tab. The keyboard should release.
    • Slide the spudger, so that the tabs do not reset after pressing each one.
  3. Acer Aspire One 532h-2806 Keyboard Replacement: 3 단계, 이미지 1/1
    • Gently lift the keyboard up.
    • The keyboard ribbon cable is still attached to the motherboard.
  4. Acer Aspire One 532h-2806 Keyboard Replacement: 4 단계, 이미지 1/1
    • Carefully unplug the connector sticker on the back of the keyboard.
    • Be gentle, do not force it out.
  5. Acer Aspire One 532h-2806 Keyboard Replacement: 5 단계, 이미지 1/1
    • Remove the keyboard.
결론
Julie Paula
회원 가입일: 01/12/17
527 평판
안내서 4개 작성하였습니다
Oakland University, Team 2-4, Ruskiewicz Winter 2017 Oakland University, Team 2-4, Ruskiewicz Winter 2017 회원
OAK-RUSKIEWICZ-W17S2G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 360
