주요 콘텐츠로 건너뛰기
Acer Aspire One 532h-2806 Screen Replacement
필요한 것
  1. Acer Aspire One 532h-2806 Screen Replacement, Screen: 1 단계, 이미지 1/2 Acer Aspire One 532h-2806 Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Turn the device off before beginning any replacements.
    • Locate the two circular black stickers at the bottom corners of the laptop screen.
    • Remove the stickers.
    • Two 6mm Phillips Screws should now be visible.
  2. Acer Aspire One 532h-2806 Screen Replacement: 2 단계, 이미지 1/2 Acer Aspire One 532h-2806 Screen Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #0 Screwdriver to remove the two 6mm screws from the screen.
  3. Acer Aspire One 532h-2806 Screen Replacement: 3 단계, 이미지 1/2 Acer Aspire One 532h-2806 Screen Replacement: 3 단계, 이미지 2/2
    • Using the opener tool, remove the plastic cover, surrounding the screen.
    • It is normal to hear clicking sounds as the plastic cover is removed.
  4. Acer Aspire One 532h-2806 Screen Replacement: 4 단계, 이미지 1/3 Acer Aspire One 532h-2806 Screen Replacement: 4 단계, 이미지 2/3 Acer Aspire One 532h-2806 Screen Replacement: 4 단계, 이미지 3/3
    • Remove the four 6mm Phillips screws surrounding the screen.
    • These are holding the screen in place. After the screws are removed, the screen should remove itself from the plastic outer cover.
  5. Acer Aspire One 532h-2806 Screen Replacement: 5 단계, 이미지 1/1
    • Peel back the fuss cable from the outer laptop plastic cover.
    • Be careful, not to yank or rip the cable, it should gently peel back.
  6. Acer Aspire One 532h-2806 Screen Replacement: 6 단계, 이미지 1/1
    • Locate the ZIF (zero insertion force) Cable.
    • Peel back any tape if necessary
    • Carefully unplug it.
    • Do not pull hard, it should remove itself easily.
  7. Acer Aspire One 532h-2806 Screen Replacement: 7 단계, 이미지 1/2 Acer Aspire One 532h-2806 Screen Replacement: 7 단계, 이미지 2/2
    • Remove the two 6mm screws on each side of the screen with a Phillips #0 screwdriver.
  8. Acer Aspire One 532h-2806 Screen Replacement: 8 단계, 이미지 1/3 Acer Aspire One 532h-2806 Screen Replacement: 8 단계, 이미지 2/3 Acer Aspire One 532h-2806 Screen Replacement: 8 단계, 이미지 3/3
    • Remove the screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Julie Paula
회원 가입일: 01/12/17
527 평판
안내서 4개 작성하였습니다
Oakland University, Team 2-4, Ruskiewicz Winter 2017 Oakland University, Team 2-4, Ruskiewicz Winter 2017 회원
OAK-RUSKIEWICZ-W17S2G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 297
