주요 콘텐츠로 건너뛰기
Acer Aspire One 722 Hard Drive Replacement
필요한 것
  1. Acer Aspire One 722 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire One 722 Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
  6. Acer Aspire One 722 Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1개 중 1개
    • Ensure the Laptop is powered down with the battery removed prior to beginning.
    • With the battery cavity facing away from you, use the Phillips #0 to remove the center screw which secures the backplate.
    • Make sure to keep track of these screws for reassembly.
  7. Acer Aspire One 722 Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Gently lift up and pull away the backplate from the chassis to remove.
  8. Acer Aspire One 722 Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • With the backplate removed, locate the HDD in the upper left corner of the device.
    • Use the Phillips #0 screwdriver to remove the four corner screws securing the HDD to the chassis.
  9. Acer Aspire One 722 Hard Drive Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire One 722 Hard Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Gently lift and secure the HDD with one hand and carefully remove the SATA and power connections with your other hand.
    • Once removed, store the replaced drive in an anti-static environment to ensure its integrity.
  10. Acer Aspire One 722 Hard Drive Replacement: 10 단계, 이미지 3개 중 1개 Acer Aspire One 722 Hard Drive Replacement: 10 단계, 이미지 3개 중 2개 Acer Aspire One 722 Hard Drive Replacement: 10 단계, 이미지 3개 중 3개
    • With your replacement HDD in hand, reseat the power and SATA cables removed from the previous drive.
    • The plugs are diffrent sizes so there is no fear of mixing them up
    • With the cables attached, align the four mounting points in the corner of the drive with the chassis and reseat the four Phillips #0 screws that were removed earlier.
결론
To reassemble your device, follow these instructions in reverse order., taking special care in replacing the back cover. and battery.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Christian Barboza
회원 가입일: 10/25/15
818 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G6
3 회원들
안내서 10개를 작성함
댓글 한 개
لا يعمل بعد انسطاب عليه ماء ما الحل
Belql Sayes - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 29
전체 시간: 5,701
