주요 콘텐츠로 건너뛰기
Acer Aspire One 722 Keyboard Keys and Battery Replacement
필요한 것
  1. Acer Aspire One 722 Keyboard Keys and Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire One 722 Keyboard Keys and Battery Replacement: 4 단계, 이미지 2개 중 2개
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
  6. Acer Aspire One 722 Keyboard Keys and Battery Replacement, Keyboard Keys and Battery: 6 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry off the keyboard key.
    • If the key is broken, just remove the broken key and press a new key down over the empty key area. If you need to repair the key, follow the steps below.
  7. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire One 722 Keyboard Keys and Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Use a spudger to pry the upper portion on both sides of the mechanism until it pops off from the key socket.
  8. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 8 단계, 이미지 3개 중 1개 Acer Aspire One 722 Keyboard Keys and Battery Replacement: 8 단계, 이미지 3개 중 2개 Acer Aspire One 722 Keyboard Keys and Battery Replacement: 8 단계, 이미지 3개 중 3개
    • Take both pivoting pieces of the mechanism and put them together.
    • The smaller piece fits through the inner part of the larger piece and lays in the groove of the larger piece.
    • Once assembled, it should be entirely flat.
  9. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 9 단계, 이미지 1개 중 1개
    • Position the pivoting smaller piece of the key mechanism in the lower hooks of the key socket.
    • Slide your finger across the upper portion of the key mechanism so that it locks in place with the upper hooks of the key socket.
  10. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 10 단계, 이미지 1개 중 1개
    • Place the key on top of the empty key space and press it down firmly until the key locks in place.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Christian Barboza
회원 가입일: 10/25/15
824 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G6
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 18
전체 시간: 4,651
