주요 콘텐츠로 건너뛰기
Acer Aspire One 722 RAM Replacement
필요한 것
  1. Acer Aspire One 722 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 RAM Replacement: 2 단계, 이미지 1/1
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 RAM Replacement: 3 단계, 이미지 1/1
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 RAM Replacement: 4 단계, 이미지 1/2 Acer Aspire One 722 RAM Replacement: 4 단계, 이미지 2/2
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 RAM Replacement: 5 단계, 이미지 1/1
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
  6. Acer Aspire One 722 RAM Replacement, RAM: 6 단계, 이미지 1/1
    • Remove the screw at the bottom of the laptop.
  7. Acer Aspire One 722 RAM Replacement: 7 단계, 이미지 1/1
    • Take the plastic backing plate off.
  8. Acer Aspire One 722 RAM Replacement: 8 단계, 이미지 1/1
    • Unclip the two metal braces that hold the RAM in place by pushing the metal clips outwards away from the RAM itself.
    • The RAM should pop up.
  9. Acer Aspire One 722 RAM Replacement: 9 단계, 이미지 1/1
    • Grab the RAM and remove slowly.
  10. Acer Aspire One 722 RAM Replacement: 10 단계, 이미지 1/1
    • Take the replacement RAM stick and line up the the grooves on the RAM to the grooves on the netbook so that they will fit in flush.
  11. Acer Aspire One 722 RAM Replacement: 11 단계, 이미지 1/1
    • Press down on the RAM stick and the metal clips will lock in to place.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Christian Barboza
회원 가입일: 10/25/15
818 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 17
전체 시간: 1,944
